Go to Post OK, repeat after me "FIRST is not about the robot". - Foster [more]
Unread 31-01-2015, 17:41
admrialkunkka admrialkunkka is offline
FRC #2815
admrialkunkka is an unknown quantity at this point
FRC Sim is not installing
I am trying to install the FRC Sim on my linux machine, however it is not working. When I execute:
Code:
wget first.wpi.edu/FRC/roborio/release/frcsim-installer.sh -O ~/Downloads/frcsim-installer.sh && chmod +x ~/Downloads/frcsim-installer.sh && ~/Downloads/frcsim-installer.sh INSTALLER
I receive the error
Code:
W: Failed to fetch http://first.wpi.edu/FRC/roborio/release/linux/dists/utopic/main/binary-amd64/Packages  404 Not Found
W: Failed to fetch http://first.wpi.edu/FRC/roborio/release/linux/dists/utopic/main/binay-i386/Packages  404 Not Found
Does anyone have the correct link or know how to fix this?
Unread 31-01-2015, 17:47
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: FRC Sim is not installing
That error indicates you're using Ubuntu 14.10. FRC Sim is supported on 14.04:
At this time, to run FRCSim, it is necessary to install Ubuntu 14.04 (64bit).
http://wpilib.screenstepslive.com/s/...talling-ubuntu
