Go to Post Volunteers are in short supply and we always need more. - Koko Ed [more]
Unread 31-01-2015, 19:40
1452-Leo 1452-Leo is offline
FRC #1452 (Omnicats)
Rookie Year: 2014
1452-Leo is an unknown quantity at this point
[C++] Use CAN Talons in RobotDrive
We are using CAN for the first time and after a few hours of learning how to do it, wiring, and formatting the Talons, our drive code didn't work. I tried controlling each motor individually and it works perfectly, but we would like to use RobotDrive because we are using Mecanum wheels with a gyro. Here is the non-working code:
Code:
class Robot: public SampleRobot {
	Joystick driveStick;
	CANTalon leftFront;
	CANTalon leftBack;
	CANTalon rightFront;
	CANTalon rightBack;
	RobotDrive drive;
	Gyro gyro;
public:
	Robot() :
		driveStick(1),
		leftFront(1),
		leftBack(5),
		rightFront(2),
		rightBack(6),
		drive(leftFront, leftBack, rightFront, rightBack),
		gyro(0)
	void OperatorControl() {
		gyro.InitGyro();
		gyro.Reset();
		while (IsOperatorControl() && IsEnabled()) {
			drive.MecanumDrive_Cartesian(driveStick.GetX(),driveStick.GetY(),driveStick.GetThrottle(),gyro.GetAngle());
And here is the working code (I used tank drive to make it easier):
Code:
	CANTalon leftFront;
	CANTalon leftBack;
	CANTalon rightBack;
	Gyro gyro;
public:
	Robot() :
		driveStick(1),
		leftFront(1),
		leftBack(5),
		rightFront(2),
		rightBack(6),
		gyro(0)
		gyro.InitGyro();
		gyro.Reset();
			leftFront.Set(-driveStick.GetY());
			leftBack.Set(-driveStick.GetY());
			rightFront.Set(driveStick.GetThrottle());
			rightBack.Set(driveStick.GetThrottle());
Does anyone know why this doesn't work? Thanks!
Unread 31-01-2015, 19:53
viggy96 viggy96 is offline
FRC #3331
Rookie Year: 2010
viggy96 is infamous around these partsviggy96 is infamous around these partsviggy96 is infamous around these parts
Re: [C++] Use CAN Talons in RobotDrive
Have you tried connecting the TalonSRXs via the PWM? That may alleviate your problem. Could also check if your TalonSRXs have the latest firmware.
Check here: http://crosstheroadelectronics.com/T...7s%20Guide.pdf
Unread 31-01-2015, 20:09
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Maybe grab the self test from the Rio web based configuration? Maybe its not in percent throttle mode. I don't have the implementation of robot drive in front of me but I think it just uses Set().
Unread 31-01-2015, 20:10
James Kuszmaul James Kuszmaul is offline
NEFIRST CSA
FRC #0971 (Spartan Robotics)
Rookie Year: 2011
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
What sort of problems are you encountering when you try to run the mecanum drive code? Does it simply not do anything at all, does it move the motors around but not in the way you expect, or something else? If the motors are running but the robot is responding how you expect, you should double check that everything is plugged into the right ports, that all the motors are turning the right direction, etc.
FRC971 (Student) 2011-2014
FRC190 (College Mentor-ish) 2014
WPILib Development 2014-present
Unread 31-01-2015, 20:28
Rookie Year: 2014
I updated all the Talons to 1.4 (the newest I think) and we're trying to use CAN instead of PWM. Using PWM would involve soldering the CAN wires which we don't want to do just yet.
I actually did do this earlier, but I had no idea what is means. When in drive, they are set to "No Drive" but otherwise set to "Throttle." This seems like it could be the problem if I knew more about it.
Motors are not doing anything at all, but works fine when not using RobotDrive.
Unread 31-01-2015, 20:48
NEFIRST CSA
Rookie Year: 2011
try calling
robotDrive.SetSafetyEnabled(false);
before the while loop in OperatorControl.
Edit: actually, try calling that in the Robot() constructor. It's possible that the Talons are getting disabled before you start running the robot but that they aren't getting properly re-enabled.
Unread 31-01-2015, 20:54
Rookie Year: 2014
try calling
I actually tried that earlier when I had some motor controllers set up wrong, but I forgot to try it again! I'll check back tomorrow and report if it worked or not.
Unread 31-01-2015, 20:57
ozrien's Avatar
Omar Zrien
AKA: Omar
If you are seeing kNoDrive then most likely set is not being called. See software reference manual for more details.
Unread 31-01-2015, 21:12
Rookie Year: 2014
Can I just call Set() once at the beginning of teleop or is there something I have to change in RobotDrive? Unfortunately, I can't test until Monday.
Unread 31-01-2015, 22:48
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
Rookie Year: 2011
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Are you calling Wait(.01) in your code? That may cause the code to do nothing.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 01-02-2015, 00:09
FRC #3331
Rookie Year: 2010
Could also try creating a new project. Sometimes projects get messed up. On the surface, it may not seem like it matters, but it could be worth a try.
I reccomend you switch from using the SampleRobot project to using IterativeRobot and try the code again.
Unread 01-02-2015, 00:45
FRC #3331
Rookie Year: 2010
This should work, but as I don't have a bot with TalonSRXs, I can't confirm this, but you could try it. I have used the IterativeRobot class.
Code:
class Robot: public IterativeRobot
private:
	LiveWindow *lw;
	CANTalon leftFront = new CANTalon(1);
	CANTalon leftBack = new CANTalon(5);
	CANTalon rightFront = new CANTalon(2);
	CANTalon rightBack = new CANTalon(6);
	RobotDrive drive = new RobotDrive(leftFront, leftBack, rightFront, rightBack);
	Joystick stick = new Joystick(1);
	Gyro gyro = new gyro(0);
	void RobotInit()
		lw = LiveWindow::GetInstance();
	void AutonomousInit()
	void AutonomousPeriodic()
	void TeleopInit()
	void TeleopPeriodic()
		drive.MecanumDrive_Cartesian(stick.getX(), stick.getY(), stick.getThrottle(), gyro.getAngle());
	void TestPeriodic()
		lw->Run();
Unread 01-02-2015, 16:29
Rookie Year: 2014
How would this be different than the code I started with? Iterative basically just adds a function to be called at the beginning, but doesn't really change what is actually going on in the program.
Unread 02-02-2015, 01:19
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Iterative waits for each driver station packet for each iteration, whereas your original code runs in a tight loop without waiting for input. If you added a 20ms sleep in your loop, it would be vaguely equivalent to the iterative version.
Either way, you should add some sleep to your loop, otherwise you'll starve the rest of the threads on your system and you'll encounter problems. I'd recommend using iterative robot instead though, then you don't have to worry about things like that.
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
  #15   Spotlight this post!
Unread 03-02-2015, 10:14
Rookie Year: 2014
Thanks, I didn't realize there was an actual difference in the how the program ran for iterative, so we will probably switch over to it today.
