Go to Post You know you've been in FIRST way too long when you can remember all those hints... even down to exact wording... and only have to look up the most recent. - EricH [more]
Unread 05-02-2015, 23:19
1452-Leo 1452-Leo is offline
FRC #1452 (Omnicats)
Rookie Year: 2014
1452-Leo is an unknown quantity at this point
Re: [C++] Use CAN Talons in RobotDrive
I tried turning the safeties off already and it didn't work, but I'll try the disabled loop tomorrow and get back. I agree that dummy PWMs is a bad solution, but we're going all CAN this year so it shouldn't really affect anything, and we will probably revert to it if your solution doesn't work because we've spent too long trying to get this to work. Thanks for the help though!
Unread 07-02-2015, 21:14
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond repute
Turning off the safeties in the CANTalons is not sufficient. They are already off (they default off). The problem is RobotDrive has it's own safety enable.
Anyway if you are still seeing the EXACT symptom of "...Motor Safety Timeout..." errors in the DS then you need to remedy it. Even with the PWM workaround (eek) you're still generating errors in your DS log. That's going to prevent your drive team from seeing other reported errors (because they will get used to seeing errors in that area of the DS".
m_robotDrive->SetSafetyEnabled(false); will absolutely prevent MS errors. If you are still seeing them then something is very wrong, and it will likely be a problem throughout the season.
Unread 13-02-2015, 17:54
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Definitely turn off the motor safety on the RobotDrive object, not the individual motor controllers and see if that fixes the problem. In the library, RobotDrive is the only place where the motor safety stuff is enabled by default, and as Omar said, it is part of the RobotDrive class as a whole. The thought was that it would stopping the runaway program from driving on it's own was the highest priority.
Use something like:
drive.SetSafetyEnabled(false);
Please let us know if does it for you.
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
