Go to Post The "line" is the point at which we've raised the floor so high that the advanced teams are hitting the ceiling. The ceiling is pretty darned high (and the GDC keeps raising it), so I don't think we're in danger of that any time soon. - EricVanWyk [more]
Unread 01-02-2015, 10:32
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
Rookie Year: 2014
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
RoboRIO red comm light, not accepting code?
Our PDP is giving us an orange light, and our roboRIO is giving us a red comm light. When we deploy code, eclipse reports it as deployed, but the roboRIO does not seem to get the new code. The ni web browser does NOT report a sticky fault.
Technical Details:
RoboRIO is imaged
Can ID's are correct
No fuses appear to be blown
Driver station can connect, but does not report any code
Unread 01-02-2015, 10:50
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: RoboRIO red comm light, not accepting code?
Is the roboRIO perhaps set to not run the user program on startup?
Unread 01-02-2015, 13:58
AKA: Ahad Bawany
no team (None)
Rookie Year: 2014
Commenting out the auto code I had added fixed the red comm light. Does anyone mind reading through the code to see what might be causing the error?
Code:
void AutonomousInit()
		//gyro->Reset();
	void AutonomousPeriodic()
	SmartDashboard::PutNumber("Gyro Angle:", Angle);
if (automode == 1)
	gyro->GetAngle();
	if (Angle == 90)
		robottime = false;
	} else {
		robottime = true;
if(robottime == true)
	robot->Drive(0,-1);
if (robottime == false)
	robot->Drive(0,-1);
if (automode == 2)
	gyro->GetAngle();
	if (Angle == 45)
		robottime = false;
	} else {
		robottime = true;
	if (robottime == true)
		robot->Drive(0, -.5);
		robot->Drive(0,0);
is using a selector based on joystick button during robotinit causing this?
Unread 01-02-2015, 13:59
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
I'd wager that either robot or gyro is an uninitialized pointer.
Unread 01-02-2015, 21:51
AKA: Ahad Bawany
no team (None)
Rookie Year: 2014
That doesn't seem to be it. To clarify, eclipse doesn't give us any errors when we deploy or build; the roboRIO gives us a red comm light when we deploy it, and it gets no code. It gets code fine if auto is commented out. Here's a sample with the robotinit part to clarify that:
Code:
#include "WPILib.h"
class Robot: public IterativeRobot
private:
	//Initializing livewindow
	LiveWindow *lw;
	//Initializing stick
	Joystick *stick;
	//Initializing the Chassis parts
	Talon *kFrontLeftMotor;
	Talon *kFrontRightMotor;
	RobotDrive *robot;
	Relay *Fan;
	DoubleSolenoid *shifter;
	Encoder *ChassisEnc;
	Encoder *OtherEnc;
	//Initializing the values for Cheesy Drive
	float Rotation;
	float Acceleration;
	float rightMultiplier;
	float leftMultiplier;
    double automode;
    Gyro *gyro;
    bool robottime;
    double Angle;
	void RobotInit()
		SmartDashboard::init();
		lw = LiveWindow::GetInstance();
		stick = new Joystick(0);
		kFrontLeftMotor = new Talon(0);
		kFrontRightMotor = new Talon(1);
		robot = new RobotDrive(kFrontRightMotor, kFrontLeftMotor);
		Fan = new Relay (3);
		/* Setting the shifter as a DoubleSolenoid
		 * Because we're using both pistons off of
		 * one Double Solenoid
		shifter = new DoubleSolenoid (0,1);
		ChassisEnc = new Encoder (0,1, false, Encoder::EncodingType::k4X);
		OtherEnc= new Encoder (8,9, false, Encoder::EncodingType::k4X);
		//Setting it so the fan is off by default
		Fan->Set(Relay::kOff);
		//Setting the Rotation and Accel values
		Rotation = stick->GetRawAxis(1);
		Acceleration = stick->GetRawAxis(3);
	    /*Setting the multipliers
	     * so that they don't allow
	     * a robot to go full forward
	     * while going full turn
		rightMultiplier = Rotation + Acceleration;
		leftMultiplier = Rotation - Acceleration;
		//Setting the shifter to Low Gear
		shifter->Set(DoubleSolenoid::kReverse);
		robot->SetInvertedMotor(RobotDrive::kFrontLeftMotor, true);
		robot->SetInvertedMotor(RobotDrive::kFrontRightMotor, true);
		ChassisEnc->SetDistancePerPulse(11.04);
		OtherEnc->SetDistancePerPulse(11.04);
	/*gyro = new Gyro (2);
	Angle = gyro->GetAngle();
	if (stick->GetRawButton(1))
			automode = 1;
		if (stick->GetRawButton(2))
Unread 01-02-2015, 21:54
The gyro constructor is commented out in the code you just posted, and your gyro appears to be on a channel that won't work. It needs to be on Channels 0 or 1.
Unread 01-02-2015, 22:36
AKA: Ahad Bawany
no team (None)
Rookie Year: 2014
Yeah, it was commented out after deploying, along with the auto code. Confused about the second sentence, doesn't the gyro have four ports it can plug into? Sorry for slow replies BTW, school WiFi does not let me post on chief Delphi, other than starting threads.
Unread 01-02-2015, 23:03
The Analog Accumulators used for the gyro are only on channels 0 and 1.
See Gyro: http://first.wpi.edu/FRC/roborio/rel...classGyro.html
And AnalogInput kAccumulatorChannels : http://first.wpi.edu/FRC/roborio/rel...alogInput.html
Unread 01-02-2015, 23:23
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
Rookie Year: 2011
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Try looking at the logs on the Dashboard. Usually they'll give you an error.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 04-02-2015, 21:43
AKA: Ahad Bawany
no team (None)
Rookie Year: 2014
Changing gyro port to 1 fixed it! Thanks. The only thing I can't figure out is how to have multiple auto modes without using the selectable chooser. It seems that only works with command based robot?
