Go to Post We got spirit yes we do! What? You don't have spirit? What's wrong with you? - Koko Ed [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 01-02-2015, 15:02
electrical238 electrical238 is offline
FRC #0238
electrical238 is an unknown quantity at this point
Exclamation CAN wire replacement?
I need some help for Wiring the CAN on the robot for the new control system. Can you use a replacement wires for the CAN-Bus? What I have in mind is using a 22 gauge blue and yellow wire that we have a ton of because our CAN Wires that came with the Robo-Rio are too short. Is this Legal? or can I not do this. Thanks!
Unread 01-02-2015, 15:05
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: CAN wire replacement?
There are (currently) no color requirements for CAN bus wiring. (Q172)
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 01-02-2015, 16:03
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
I usually just acquire 20 or 22 gauge green/yellow, and use a drill to quickly twist them.
Although the colors may not be required, we highly recommend following the green/yellow scheme for the following reasons.
-Makes robot inspection and troubleshooting easier.
-The colors will match what's labeled on the roboRIO CAN connector
-The colors will match what's labeled on the PDP/PCM Weidmuller connectors.
-The colors match the Talon SRX cable harness.
It all adds up to a better CAN bus experience.
Unread 10-02-2015, 06:35
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Is there any digrame so to see how to conect Talons.
My Next quation is butter than PWM
TEAM 1946-Tamra
Unread 10-02-2015, 09:22
ozrien's Avatar
Omar Zrien
AKA: Omar
Did you read the Talon SRX User's Guide?
Unread 10-02-2015, 17:22
yara92's Avatar
AKA: Mohamed
I FOUND IT AT:
http://crosstheroadelectronics.com/Talon%20SRX%20User's%20Guide.pdf
TEAM 1946-Tamra
Unread 10-02-2015, 18:02
ozrien's Avatar
Omar Zrien
AKA: Omar
Cool, I usually just Google "Talon SRX User's Guide".
But was it helpful in answer your questions about wiring?
Unread 11-02-2015, 02:23
yara92's Avatar
AKA: Mohamed
Uncule google help
TEAM 1946-Tamra
