Go to Post Winning the robot part of the competition is not about learning or doing unneccesary work. It works just like "winning" in industry. - Max Lobovsky [more]
Unread 01-02-2015, 15:11
cakeisajoke cakeisajoke is offline
2557 Programmer
AKA: Philip Rader
FRC #2557 (SOTABots)
Team Role: Coach
Rookie Year: 2012
cakeisajoke is an unknown quantity at this point
Wiring AXIS M1013 to 2015 system
I have a question regarding wiring the Axis M1013 network camera to the 2015 control system. The camera is rated for 5V@1.5A. The camera will run fine with 5V@2A, which the Voltage Regulator Module supplies. However, the VRM's 5V@2A terminals are reserved for the Wireless Bridge, as stated in R32:
"The Wireless Bridge power must be supplied by the 5V 2A (“Radio”) output of a Cross the Road Electronics Voltage Regulator
Module (VRM) (P/N: am-2857, 217-4245) and must be the only load connected to those terminals."
If the Wireless Bridge is the only load allowed on those terminals, where do we plug in the Axis Camera for power?
Unread 01-02-2015, 15:33
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
Rookie Year: 2012
tStano will become famous soon enough
Re: Wiring AXIS M1013 to 2015 system
I'm struggling with this as well.
I've come up with 2 possible solutions:
1. Buy a second VRM for your camera(Honestly, this VRM seems poorly designed, I can't think of anything I would use any of the ports except the 5V2A for)
2. I'm not entirely sure if this would work, but I think you could use the router power supply from last year plugged directly into a wago on the PDP. That supply is a 12v-5v supply, but the camera requires a very specific voltage and I don't know how good the regulator is in the router power supply.
edit: I looked up the spec sheet for that, says it works from 10-30v, which doesn't sound too promising. I know our batteries get down below 10 during some matches.
Perhaps you could put that thing off the 12V2A rail of the VRM, although I'd advise against it, especially if you're using pneumatics with your compressor PCM plugged into the weidmuller connectors, because your compressor, solenoids, and anything off the VRM will run off a single 20A non-resetting fuse.
Unread 01-02-2015, 15:36
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
We just bought a second VRM. You could also reuse the radio power converter from the previous control system and connect it to the 12 V side of the VRM.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 01-02-2015, 16:29
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
ozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond repute
The VRM was designed specifically for FIRST use. Teams need 5V and 12V.
Having boosted 5V and 12V is great because of the different radios teams have collected over the years. And they are boosted to tolerate battery voltage drops.
The radio selection changes year-to-year, the VRM allows us to be flexible and support the widest combo of peripherals. Seems like a good design practice to me.
R37 tells us additional (non-radio) VRMs can be connected to the WAGO slots on the PDP. So you don't have to rely on the 20amp fused weidmuller if that's a concern. Seems like a good solution for camera.
Unread 01-02-2015, 18:02
AKA: Sparks
Rookie Year: 2012
It was harsh and wrong of me to say it was a poor design decision, because I don't know the design constraints, but it doesn't make sense for my team.
There are definitely ways around that 20A fuse. It just is something to think about/design around. Its illegal to run the radio and anything else(eg camera) off the 5V2A slot.
The radio selection has been a 5v dlink for quite a while. I know my team, at least, doesn't have anything else(unless you count the IFI CS). It is a good idea to plan for different radio styles, though I would predict its either going to be a d-link or a USB radio in the future, I predict this because the wiring diagram released a while ago showed a USB radio. I could definitely be off base though.
All I'm saying 45$ seems like a lot to spend for a 2A unregulated 12vdc to regulated 5vdc converter. I understand that it does other things, but I don't personally forsee ever having a use for those other things. Other teams might, and more power to them.
I would like something that is just an unregulated 12v to regulated 5v converter for about half the price. I'm searching the internet for one. That has to be a thing you can buy. Maybe not though. maybe thats just what regulators cost; I find that hard to believe though, because of the 10-30v to 5v converter available on andymark for 16$.
Edit: I'm not saying its overpriced for what it is, I'm saying its overpriced for what I would use it for(powering a camera or 5v lights).
Unread 01-02-2015, 18:11
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
I think the VRM is neither poorly designed nor overpriced for what it is. It's a very durable regulator with multiple power supplies that's designed to be sold in small quantities.
However, when we lose functionality going to a new system, it's often quite frustrating to teams, especially considering we have to spend money to purchase the new components. We have fewer relay ports and no access to a 5V supply that can be used to power the camera that has been the default FRC camera for years.
I don't know much about the control system development process, but I hoped that having as many features and being as functional as the previous control system had would be a top priority.
Unread 01-02-2015, 18:27
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
What about this: http://www.adafruit.com/product/1385
We use one of these to power our Arduino and LED strips, but it should work fine for the camera, and it is only $10.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 01-02-2015, 18:32
AKA: Sparks
Rookie Year: 2012
That sounds excellent. Thanks!
Its currently out of stock, but I'm sure it'll come back in stock soon.
Unread 01-02-2015, 23:14
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I would like something that is just an unregulated 12v to regulated 5v converter...
Is anything wrong with the CPR-360 power converter you probably already have from past years? If you want to use a new one, AndyMark sells them as the am-0899.
Unread 02-02-2015, 01:24
AKA: Sparks
Rookie Year: 2012
That's only rated 10-30v; and the camera needs a super specific voltage range. I'm wary of that rating. Our batteries routinely go below 10v at competion. Have you had experience running a camera off that straight off battery voltage?
Edit: I understand I could run that off the 12v rail of a VRM, but then I'm wary of current draw through that 20A fuse with a compressor and solenoids. I understand I could put the compressor on a spike, but I'd rather not because I don't want one more thing to troubleshoot, and we're running low on DIO pins for the pressure switch.
Unread 02-02-2015, 07:00
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
You could also put the PCM on a 20A breaker...
Unread 02-02-2015, 13:48
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
2 of these with heatsinks plus some other basic circuitry will give you 1.5 amps of 5 volts.
http://www.radioshack.com/-5v-fixed-...jF_h4&tab=tab1
I'd rather spend $16 for the AM0899 and direct connect it to the PDP.
Unread 02-02-2015, 14:00
AKA: Sparks
Rookie Year: 2012
Good point, I thought I'd read that that was against the rules somewhere, but I was wrong. Thanks!
Unread 02-02-2015, 22:14
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Rookie Year: 2012
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
as far as i know acording to the rules even if you have 2 vrm you can only use the 5v2A for the radio power, as for the camera my team got it to run on the 5v1/2 amp i think, we also burnt out one plugging it into the 12v...teh he
