Go to Post "Needless to say, my Roomba will be making my toast from now on" -Colbert - artK [more]
Unread 02-01-2015, 04:13 PM
CoffeeFlux's Avatar
CoffeeFlux CoffeeFlux is offline
AKA: Ryan Lucia
FRC #0422 (Mech Tech Dragons)
Rookie Year: 2010
CoffeeFlux is an unknown quantity at this point
Command-Based: No Robot Code
Hey everyone, I'm using a command-based bot, as my team has historically, but am having issues with this year's code.
When I just attempt to start it, or even restart the roboRIO, I get the "No Robot Code" error, and prints only "Launching /home/lvuser/FRCUserProgram". When I ssh in, the file FRCUserProgram exists, and when I run"/usr/local/frc/bin/netconsole-host /home/lvuser/FRCUserProgram" it simply prints out the same thing as it did on the DS. If I just attempt to run the program itself, I get a segfault, and the lack of gdb/gcc or the ability to connect the bot to the internet (thanks to my school) means that I'm unable to make use a of a debugger.
My code is available here: https://github.com/team422/FRC-15
For reference, I'm working in Eclipse and building the code on a Windows 8 laptop. Also, the roboRIO is capable of running code, as I put the "Getting Started" project on the bot and it successfully ran. Any help is greatly appreciated!
Unread 02-01-2015, 04:27 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Command-Based: No Robot Code
Have you tried the eclipse remote debugger? http://wpilib.screenstepslive.com/s/...-robot-program
Unread 02-01-2015, 04:30 PM
CoffeeFlux's Avatar
AKA: Ryan Lucia
Rookie Year: 2010
Nope, I wasn't aware of that, thanks!
Unread 02-01-2015, 05:50 PM
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
because its not called gdb. It is called arm-frc-linux-gnueabi-gdb as it is a cross debugger. Though I would recommend using eclipse as that does all the proper magic for you to call arm-frc-linux-gnueabi-gdb
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 02-02-2015, 12:06 PM
one_each one_each is offline
FRC #4057 (KB Bots)
Rookie Year: 2012
one_each is an unknown quantity at this point
We were seeing the same behavior in our code. For us, it turned out to be accessing a (NULL) pointer before it was initialized.
