Go to Post Design is iterative, right? - JesseK [more]
Unread 01-02-2015, 16:40
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
Rookie Year: 2010
jojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of light
Tuning off the compressor manually
Hello,
I'm wondering if we can manually turn the compressor off without having the pressure sensor turn it off.
I want to have the compressor off when certain buttons are pressed and back on when they are released, but with the new PCM and the CAN integration, I'm not sure how to do this.
Thanks!
Unread 01-02-2015, 16:41
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
Re: Tuning off the compressor manually
You can still run it from a spike and turn it off
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 01-02-2015, 16:53
forbes's Avatar
forbes forbes is offline
Software developer
AKA: Evan Forbes
FRC #3507 (Ubotics)
Rookie Year: 2012
forbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to behold
I believe these start and stop vi's should do it:
Unread 01-02-2015, 18:35
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
This worked, but I had to work with it a bit.
Since (with the new 2015 Labview revision) I didn't create a compressor RefNum, I just created a constant from the INPUTS of those Start and Stop refnums and made the PCM ID 0 (like it is on our robot)
Worked perfectly. Thanks!
