Go to Post Don't let what you think you can do get in the way of what you can do. - Daniel_LaFleur [more]
Unread 01-02-2015, 17:33
Asymons Asymons is offline
FRC #4716 (Purple Raiders)
Team Role: Driver
Rookie Year: 2013
Asymons is an unknown quantity at this point
LEDs on the REV RIODuino
Hi Everyone,
I have a question in regards to programming the LEDs on a REV RIODuino. Would it be possible to program the micro-controller board to light LED's by response of a Joystick Command (like pulling the trigger)? Or would it be more practical to lets say have the LEDs function through particular commands on the robot? The goal of this is to have LED's as a mechanism to not only look pretty, but to help human players know when to load a tote into the robot (Green being ready, red being not ready ). Thank you for any help!
Unread 03-02-2015, 00:14
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
Rookie Year: 2007
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Re: LEDs on the REV RIODuino
Originally Posted by Asymons View Post
Hi Everyone,
Hey Asymons,
Both scenarios are quite practical.
First you should set up a way to communicate between the roboRIO and the RIOduino. There are many options, but I2C and Serial (UART) connections are already made between the two when the RIOduino is plugged into the MXP.
You'll then write code on your RIOduino that responds to commands or signals from your roboRIO.
Those commands can be simple: when the RIOduino gets the "red" command, it changes the LEDs to red, when it gets "off" it turns them off, etc.
They can also be more complex: the roboRIO sends the current robot state, and the RIOduino decides what to do.
The code on the roboRIO will need to take input (joystick values, sensor values, and/or robot state) and decide what command to send to the RIOduino.
AndyMark published an example using the RIOduino with a touch screen shield. Look at the "Files & Documents" tab on the RIOduino with 2.8" Touchscreen (am-2999) bundle page.
Take a look at that example to see how they communicate between the roboRIO and the RIOduino. With some modification, you can send commands to your RIOduino LED code rather than the RIOduino touch screen code.
-David
David Yanoshak
Co-founder REV Robotics | www.revrobotics.com
