Go to Post There is no such thing as reading too much into things. Such ideas are blasphemous in nature! - Guppy294 [more]
Unread 02-02-2015, 01:45
yonisav yonisav is offline
FRC #4712 (TracBots)
Rookie Year: 2013
yonisav is an unknown quantity at this point
Exclamation Read MJPG pausing my programme
Hello chief delphy
I started recently working on our vision proccecing, but I am unable to run my programme, since every time it runs the "Read MJPG" loop pauses it.
I tried to use the example that comes with the programme, but to the same exact results.
It seems that when I unpause it runs again, but pauses at the exact same point.
There are no Errors in the code. I am using an IP camera.
Thank you very much for your help.
Unread 02-02-2015, 06:22
Re: Read MJPG pausing my programme
Does the VI have a breakpoint set? It will have a red border around the object. You can use the find command to locate it, if there is one.
Choose Edit>>Find and Replace, or ctl-f, and the dialog should open.
In the top row, make sure it is on Objects. On the centered square selector, click, goto Other, and choose the stop symbol.
If it is not a breakpoint, does the pause button in the toolbar turn red?
If either of these is the issue, remove it and save the VI.
Greg McKaskle
Unread 02-02-2015, 08:14
Rookie Year: 2013
It does turn red, I'll try it and come back
Thank you ^_^
