Go to Post Our job is to play the game that the GDC gave us, not the one we think they should have given us. - Herodotus [more]
Unread 02-02-2015, 10:54
5580SQUAD 5580SQUAD is offline
FRC #5580
5580SQUAD is an unknown quantity at this point
Jittery Motor
We hooked up a BAG motor using a versaplanetary gearbox at a 7:1 ratio. It is well greased but it doesn't run smoothly on full forward, and runs terribly on full reverse. We have calibrated them. There is a video below. Anyone have any thoughts?
https://www.facebook.com/video.php?v=987754734586315
Unread 02-02-2015, 11:07
Deke's Avatar
Deke Deke is offline
no team (No Team)
Rookie Year: 2013
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
Re: Jittery Motor
One thing we had to do this year is grind off the back of one of the pinion pins that is pressed in, to give it clearance. The pin was interfering with other components, and didn't sound healthy when running. That was a 5:1 gear set, but I would suspect that the same tooling is used to assemble 7:1 gear sets as well.
I would check all the components for other interference locations as well, there are a lot of moving parts that might cause headaches.
Other than the minor pin interference, we are very happy with the performance and flexibility of the gearboxes.
Unread 02-02-2015, 11:11
Andrew Lawrence
Posts: n/a
Re: Jittery Motor
It is likely the planetary. Have you removed the motor and tested it by itself to see how the motor runs outside the gearbox? If you can isolate the problem to the gearbox itself, it becomes a lot simpler to solve.
Unread 05-02-2015, 21:16
DarkRune DarkRune is offline
AKA: Dylan Baker-Flynn
FRC #4159 (CardinalBotics)
Team Role: Driver
Rookie Year: 2012
DarkRune is a jewel in the roughDarkRune is a jewel in the roughDarkRune is a jewel in the rough
Re: Jittery Motor
What's the code you are running on it? Something I've noticed with code is that it often oscillates between forward and backwards. You can also try hooking it straight up to a battery and see what happens. You can also check out the talon and maybe switch that out.
Unread 06-02-2015, 00:17
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Jittery Motor
What kind of code are you using that's doing that?
The code really shouldn't cause a motor to oscillate between forward and backwards too often, unless it is a PID loop trying to get to the exact position... (Or if your driver is rocking the robot back and forth.)
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 06-02-2015, 14:01
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Re: Jittery Motor
Check the dowel pins used to hold the planet gears. Each of our 7:1s had a dowel pin that stuck just slightly out of the backside.
-T
Unread 15-02-2015, 07:32
BlueOps4216MrG's Avatar
BlueOps4216MrG BlueOps4216MrG is offline
Coach
FRC #4216 (Blue Ops)
Team Role: Coach
Rookie Year: 2012
BlueOps4216MrG is an unknown quantity at this point
Re: Jittery Motor
Did you guys figure out the problem. We have an almost identical issue. Bag motor w/ 90:1 versaplanetary running with the new Victor SP. It worked fine directly hooked to battery but when running through the motor controller it looks and sounds like yours.
Unread 15-02-2015, 12:12
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Jittery Motor
I'm smelling a possible software issue. What is the code you're using to control this motor?
Unread 17-02-2015, 00:26
Software Architect
Re: Jittery Motor
Originally Posted by mikel392 View Post
not trying to hijack the thread but i'm having the same problem (sort of) https://www.dropbox.com/s/t9coaq7q2d...obot.java?dl=0 the lift goes up fine but it jitters a lot when reversed
Code:
    if (joyExtra.getRawButton(4))
        liftup();
    else
        liftstop();
     if (joyExtra.getRawButton(2))
        liftdown();
    else{
        liftstop();
If button 4 is pressed, it starts the lift running up, but then the fact that button 2 is not pressed stops it immediately. You need to change the logic so that button 4 runs the lift up, button 2 runs the lift down, and only if neither button is pressed does the lift get stopped.
