Go to Post It would also level the playing field by bringing the bottom up, rather than the top down. - russell [more]
Unread 02-02-2015, 12:14
AnnaliseDonavan AnnaliseDonavan is offline
FRC #4284
AnnaliseDonavan is an unknown quantity at this point
Debugging problems
Every time I run the debugging program it creates what I think is an infinate loop and I have to stop the program
package org.usfirst.frc.team4284.robot;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.buttons.JoystickButton;
import edu.wpi.first.wpilibj.buttons.Button;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
RobotDrive Drive;
Joystick drivestick;
Joystick xbox;
int autoLoopCounter;
* This function is run when the robot is first started up and should be
* used for any initialization code.
public void robotInit() {
Jaguar FL = new Jaguar (1);
Jaguar BL = new Jaguar (2);
Jaguar FR = new Jaguar (3);
Jaguar BR = new Jaguar (4);
Drive = new RobotDrive(FL,BL,FR,BR);
drivestick = new Joystick(0);
* This function is run once each time the robot enters autonomous mode
autoLoopCounter = 0;
* This function is called periodically during autonomous
/*if(autoLoopCounter < 100) //Check if we've completed 100 loops (approximately 2 seconds)
Drive.drive(-0.5, 0.0); // drive forwards half speed
autoLoopCounter++;
} else {
Drive.drive(0.0, 0.0); // stop robot
* This function is called once each time the robot enters tele-operated mode
public void teleopInit(){
* This function is called periodically during operator control
Drive.arcadeDrive(drivestick);
xbox = new Joystick(1);
Button button1 = new JoystickButton(xbox, 1),
button2 = new JoystickButton(xbox, 2),
button3 = new JoystickButton(xbox, 3),
button4 = new JoystickButton(xbox, 4),
button5 = new JoystickButton(xbox, 5),
button6 = new JoystickButton(xbox, 6),
button7 = new JoystickButton(xbox, 7);
button1.whenPressed(new ElevatorReverse());
button2.whenPressed(new ElevatorOn());
button3.whenPressed(new ElevatorOff());
button4.whenPressed(new ArmsOut());
button5.whenPressed(new ArmsIn());
button6.whenPressed(new ArmsVerticalIn());
button7.whenPressed(new ArmsVarticalOut());
* This function is called periodically during test mode
public void testPeriodic() {
LiveWindow.run();
Unread 02-02-2015, 17:14
one_each one_each is offline
FRC #4057 (KB Bots)
Rookie Year: 2012
one_each is an unknown quantity at this point
Re: Debugging problems
I'm assuming the "debugging" program is the one you listed, not "when the program is ran in with the debugger".
You didn't state if the robot is in auton or teleop. Auton is written in IterativeRobot style and (at a quick glance) should work. The teleop section seems to be in command based style but is not correct. Most of the code in teleopPeriodic() should be in the teleopInit() so it is only called once.
There are a number of programming resources at http://wpilib.screenstepslive.com/s/4485/m/13809 and in particular, I would recommend the "Debugging a robot program" and learn how to set breakpoints and single-step through your code. A debugger is great for learning how your code is working and a tool every programmer should know how to use.
