Motor Stuttering
Hello all,
We are trying to program one of our motors to move one direction when we press a button and the other direction off of a different button. We're using a Jaguar motor controller right now. When going one direction operation is normal but the reverse direction stutters. If we reverse the code we get the same results but with opposite directions. If we use the joystick axis to control this movement both directions are working. We checked that the buttons are at 1 and -1 when pressed. Things we've tried so far: Different motor Different motor controller Changed which buttons were assigned in the code Changed which directions were assigned in the code I tried searching but was having trouble with using the right keywords. Has anyone else had this problem? Is there an easier way to accomplish the same task? TIA |
Re: Motor Stuttering
Doesn't sound like a hardware problem. When this happened to us on our first lift test, we dug through the code and found conflicting instructions being sent to the motor controller when various buttons were pushed. Can you publish some of your code?
What are you programming in? Can you post your code?
This was my first thought as well. It sounds like part of your code is sending 0 and then a different part is sending 1. Is the stop command from the first button always executing when it's not pressed? That would be my blind guess.
Would you be able to post your riolog? if you're working in java or c. Also posting your code to github would be helpful, we've had a similar problem. If it's on github, it makes for other teams to help debug a little easier.
I am guessing your code is doing something like this:
Code:
if button 1 pressed then run motor forward else stop motor endif if button 2 pressed then run motor backward else stop motor endif Instead, try this: Code:
if button 1 pressed then run motor forward endif if button 2 pressed then run motor backward endif if neither button pressed then stop motor endif |
