Go to Post Some of your terminology is also a little confusing. Nothing that some massaging can't fix. - JVN [more]
Unread 02-02-2015, 13:28
igorjavaroni igorjavaroni is offline
FRC #1382 (ETEP Team)
Rookie Year: 2014
igorjavaroni is an unknown quantity at this point
Using keyboard
Hi Guys, before i start, let's imagine if your team forget the joystick at school during an event, Is there anyway to control our robot using keyboard(WSAD) to move our robot? How to do that?
Unread 02-02-2015, 13:30
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
Rookie Year: 2011
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Re: Using keyboard
It is very possible (but I don't have code at hand to show/give you).
Caution: you cannot toggle motor speeds and what not with a keyboard. It is either 1 or 0, so you'll either go full speed or not move. Just a warning.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 02-02-2015, 13:35
Rookie Year: 2014
Re: Using keyboard
Nice, but is there any library spicific to do that?
Unread 02-02-2015, 14:03
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
Re: Using keyboard
No, there is no way to do it directly through WPILib. I would use a program (maybe a SmartDashboard extension) on the DS to read the keyboard and send commands over NetworkTables. I would be very careful about accidentally creating a runaway robot.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 02-02-2015, 15:23
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Why would you want to? As a pc gamer I love wasd except for in driving games. First by nature is a driving game. A controller or joystick Is much better because it allows for more linear movements
Unread 02-02-2015, 15:45
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Using keyboard
You could have WASD add/subtract a smaller fraction to the speed in that direction (perhaps 10%). If you go this route, you probably also want a button that goes to zero from whatever speed you are doing, so you might use WAZD for increment speed, and S for "stop".
Unread 03-02-2015, 18:52
orangeandblack5 orangeandblack5 is offline
Hates LabView - Uses It Anyway
AKA: Ian Stewart
FRC #5498 (Wired Devils)
Rookie Year: 2015
orangeandblack5 will become famous soon enough
Re: Using keyboard
I would also like an answer to this.
I tried this for about 2 days to no avail (I've never used LabView before), and I would really like to know how to do this (mostly for testing purposes (such as being able to run the robot simulator without having to bring home a joystick)). If you want I can upload my unsuccessful code, but it didn't work right, so I won't right now.
Thanks in advance!
Unread 04-02-2015, 06:29
Re: Using keyboard
The VIs for reading the keyboard, like a video game does, are located in Connectivity>>Input Devices. Your dashboard will need to open the keyboard and in a loop, it will need to read the keyboard and update one or more "virtual joystick" SmartDashboard globals. I'd recommend doing a flush when setting them or it will only get transmitted to the robot at 100ms rate.
The other way to get the data to the robot is via UDP or TCP communications. You will need to make your own simple protocol, possibly just sending the keys via TCP is sufficient.
Greg McKaskle
Unread 09-04-2015, 19:22
orob's Avatar
orob orob is offline
rookie mentor
AKA: Rob O.
FRC #3206 (Royal T-wrecks)
Rookie Year: 2014
orob is an unknown quantity at this point
Re: Using keyboard
I made a custom dashboard and put buttons on it and drove with the mouse rather than wasd, but labview's method of event capturing keystrokes isn't really going to work within the framework of the robotic code unless you make a keyboard driver VI that runs like the joystick driver runs. If you have a Wii, you can use one of those controllers via bluetooth... that might be worthwhile.
