Go to Post I am speechless......but I will think of something by the time it becomes an obvious candidate for the photo caption contest. - Rich Wong [more]
Unread 03-02-2015, 11:32
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
How to Program Mecanum
Okay I have posted multiple posts and tried hours worth of useless troubleshooting and I still do not have a working program. I have gotten code from other people, but that code never works. I have gotten suggestions here but none of them seem to fix it. Our team is about to give up and redesign our chassis to put normal wheels in. In a last ditch effort I made this program. In Robot.java under autonomous you will see a lot of commented out mecanumDrive(value, value, value, value) those were used for testing when the mecanumDrive method used to be located there. They all worked for the intended direction in autonomous. I simply can't get our XBox controller to work with it. I want buttons LB and RB to control straffing and the left joystick to control forward/backward and turning. So I programmed it for that - using if statements in drivetele - thats because none of the built in polar or cartesian commands worked(everything was messed up) - and none of the buttons or joysticks on the controller make the robot do anything. I know my XBox class works because we used it for tank drive last year. I am lost and have no idea what to do so PLEASE help!
Here is the code: https://github.com/MrSTUDofCODE/NewM...team4623/robot
THANKS!!
Unread 03-02-2015, 11:37
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: How to Program Mecanum
Given the changes to the driver station this year, that is not a correct assumption. The xBox controller mapping changed.
Unread 03-02-2015, 11:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Agreed. As a quick test, try loading last year's tank drive software and see how it drives with mecanum. While you won't get anywhere near the performance that you would with rubber tires, tank mode commands on a mecanum platform shall produce the desired results for forward, reverse, spin left, and spin right.
Unread 03-02-2015, 12:46
LFRobotics's Avatar
FRC #4623
Okay - that would explain the problems I was having - the wrong joysticks were running the wrong things - what are the new mappings?
Unread 03-02-2015, 13:55
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
I googled "WPI xbox controller mapping 2015" and followed it to the following image on the team358 page:
http://team358.org/files/programming...rolMapping.jpg
Unread 03-02-2015, 13:57
3786KRRobotics 3786KRRobotics is offline
FRC #3786
3786KRRobotics is an unknown quantity at this point
If you are using the SmartDashboard, you can display the values of each axis and play around with the controller to determine which axis is altered by what. Our team has gotten mecanum wheels working on a test chassis successfully using a sidewinder joystick. We are currently in the process of implementing an XBox controller system as well. We are, however, also working with field orientation which may not be helpful for you. If you would like, here is our drive code though it is still in the works.
After taking a quick glance at your code, you may also run into issues with strafing.
If you want to strafe to the left, you want to drive the front left forward and rear left backwards while driving the front right backwards and the back right forwards. This creates a vector in only the left direction.
You are currently, with this line:
Code:
CommandBase.mecanum.mecanumDrive(-.3, .3, -.3, .3);
driving your front left backwards and rear left forwards. This will result in your end vector heading towards the middle of your robot causing it to spin it's wheels and get nowhere.
A similar approach is required for strafing right, with the wheels driving the opposite direction of strafing left.
Unread 03-02-2015, 14:02
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Not. The wheel speeds described above are all the reverse of what they should be.
Unread 03-02-2015, 14:10
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Or perhaps team 3786 has their wheels mounted incorrectly? The rollers should form an "X" when viewed from above, and a diamond when viewed from below.
This is supported by the following observation, which shouldn't ever happen with properly oriented mecanums; if the torques add up to zero, and the translation adds up to zero, and the wheels are spinning, something's wrong.
Correction: this is possible, with the front wheels spinning backwards and the rear wheels forwards (or vice versa), but the force doesn't putsh "towards the middle".
Last edited by GeeTwo : 03-02-2015 at 14:35. Reason: Added last paraagraph and end quote, then correction
Unread 03-02-2015, 14:22
LFRobotics's Avatar
FRC #4623
Those values are not the ones that are supposed to work - the ones that were suggested didn't work and I had to play around with them to make them work - all of that was already tested in autonomous and works
Unread 03-02-2015, 14:36
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Do your rollers form an X when viewed from above? Are you able to rotate?
Unread 03-02-2015, 14:44
FRC #3786
Our wheels are mounted correctly and form an "X", perhaps I was just thinking wrong at the time as I did not have access to view our chassis. At any rate, when strafing, one side should have the wheels rotating towards the outside when viewed side on, and the other side should be rotating inwards.
Unread 03-02-2015, 15:38
Ether's Avatar
Rookie Year: 1969
Just to be clear:
Assuming your wheels are mounted correctly,
Strafe Left:
- Left wheels rotate "inward"
- Right wheels rotate "outward"
Strafe Right:
- Left wheels rotate "outward"
- Right wheels rotate "inward"
... which is not the same as this:
Unread 03-02-2015, 16:10
FRC #3786
Yes, you are correct. I was mistaken.
Unread 03-02-2015, 18:30
LFRobotics's Avatar
FRC #4623
Okay I redid the program again and will test everything again tomorrow and get back to you - hopefully it works this time!
THANKS!
  #15   Spotlight this post!
Unread 05-02-2015, 16:36
cstelter cstelter is offline
Programming Mentor
AKA: Craig Stelter
FRC #3018 (Nordic Storm)
Rookie Year: 2012
cstelter will become famous soon enough
I've learned to trust Ether so I'm trying not to doubt this, but it seemed wrong to me the first time I read it.
Just to be clear:
Strafe Left:
Strafe Right:
The above didn't help me as I'm not able to visualize inward outward-- I can interpret it two different ways-- inward from the top or inward from the bottom?
My thinking is that the left front wheel driving forward means the direction that would carry the robot toward what we are calling the front i.e. counterclockwise when viewed from the left side of the robot.
So on the bottom we have a diamond and that tells me that the wheel rotating that way should create force in the forward and the left direction. (in sand, all the sand would wind up on the right side of the wheel and behind the wheel).
Likewise if I drive the left rear wheel backwards (i.e. clockwise when viewed from the left) or the direction that would carry the robot to its rear if they were normal wheels then that diamond on the bottom will be forcing the robot backwards and to the left.
Summing those, the forward and back cancel and there should be a net left motion out of the left.
On the right if you drive the front right backward (counterclockwise when viewed from the right), the angle from below is identical to the back left wheel which we also drove backwards so again that wheel should be pushing backwards and left (in my eye).
And finally the rear right wheel driving forward (clockwise when viewed from right), so here as in the left front I see it should be pushing foward and left.
So the original position by 3786KRRobotics still seems correct to me. I count equal forces forward and backwards with his incantation and a left force from all wheels.
Yet everyone else seems to agree with Ether and common sense says I should too-- but I must be missing something obvious.
Can anyone point out where I'm thinking wrong?
I need an obviator-- one who can point out the obvious to me because at the moment I can't see it.
Maybe there is something fundamental I'm just not grasping-- we used RobotDrive to handle all this for us and it works fine so I never had to properly think though it.
