Go to Post each year the chairmans award is given to the team the judges think deserve it the most, for that year. How can it be any other way? - KenWittlief [more]
Unread 03-02-2015, 20:07
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
"Cool" Squad
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Rookie Year: 2014
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Encoders with CANTalons
We are trying to use an encoder on our elevator gearbox. It is plugged through the top port into a Talon on CAN with a breakout board. How do I access this? getEncPosition, getSpeed, and getAnalogInputPosition all don't work when called on the CANTalon object.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 03-02-2015, 20:22
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
Re: Encoders with CANTalons
Are you able to control the Talon at all? What exactly happens when you try use those methods?
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 03-02-2015, 20:37
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
I'm not sure what "don't work" means, BUT you should first try to grab the value in the RIO web-based config page (see Talon srx software ref manual - section 2.4). That way you can quickly figure out if it's a wiring issue or a programming issue.
Unread 03-02-2015, 21:07
"Cool" Squad
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Rookie Year: 2014
Some of the methods return nothing, some fluctuate within a couple integers 98-102
My FRC History:
Unread 03-02-2015, 21:15
ozrien's Avatar
Omar Zrien
AKA: Omar
Well getAnalogInputPosition() will return ~100 since you likely have nothing connected to the analog input. Please read section 16.21 in the Talon SRX Software Reference Manual.
If GetEncoder() is returning zero then you should check the self-test to see what's up (Section 2.4 in the Talon SRX Software Reference Manual).
getSpeed/getPosition requires you to select which type of feedback you are using. Please see Section 7 and Section 5.3 for the java examples in the Talon SRX Software Reference Manual.
Unread 03-02-2015, 21:21
ozrien's Avatar
Omar Zrien
AKA: Omar
If you are using analogEncoders be sure to update the Talons to 1.4 (see section 21.13 for the fix).
EDIT:But at a minimum update to at least 1.1 (section 2.3 in Talon SRX Software reference manual, and also FRC rule R59).
I just assumed you were using quad encoders but now realize that might not be true. Which breakout are you using?
Unread 03-02-2015, 21:23
"Cool" Squad
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Rookie Year: 2014
Quad encoders. EDIT: Solved, encoder was bad.
My FRC History:
