Go to Post Place a corner of it on the end of a table, clamp down the other side, and have a good whack at it with a hammer (hard). If it didn't break, it was polycarbonate. - vivek16 [more]
Unread 03-02-2015, 20:43
mpirringer mpirringer is offline
FRC #1989
mpirringer is an unknown quantity at this point
Pneumatics Control module programming
Hi,
I am looking for an example to program this years PCM Do you treat them as doubesolenoids like in prior years and how do you determine the channel this year. The roborio says the pcm id is 0. need to address solenoid 1 and 2 as double stroke
TIA
