Go to Post we've got three years to perfect it. And then... who knows? - Amanda Morrison [more]
Unread 04-02-2015, 14:28
Team3220's Avatar
Team3220 Team3220 is offline
Mechanic of Mayhem
FRC #3220 (Mechanics of Mayhem)
Rookie Year: 2013
Team3220 is an unknown quantity at this point
Camera Help!
I was wondering how to configure a Microsoft LifeCAM in Labview 2015! . Apparently all cameras are pre-coded in LabView default VIs, but when we plug it into the robot, we don't get any video to the drivers station. Also, our driver's station used to open a lower and upper window, but now it only opens the lower one. Is there only supposed to be one, or is something wrong?
Thanks for the help and pictures would be greatly appreciated
Sincerely,
Team 3220
Unread 04-02-2015, 15:35
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Camera Help!
What you're calling the "upper window" is actually a separate program. The Driver Station is supposed to launch a Dashboard application on startup, and it's the Dashboard which displays the camera image.
Try changing the Dashboard Type selector from "Default" to "LabVIEW" or vice versa. That should make the standard dashboard run.
Unread 04-02-2015, 18:11
Team3220's Avatar
Mechanic of Mayhem
Rookie Year: 2013
Re: Camera Help!
I figured it out. Thanks!
