Go to Post Now Dave, before you get all snarly about these- remember, I still have the button maker... - MissInformation [more]
Unread 04-02-2015, 15:03
anthonygraff24 anthonygraff24 is offline
FRC #2872 (CyberCats)
Rookie Year: 2012
anthonygraff24 is an unknown quantity at this point
Problem Downloading Code to Robot
When I tried to deploy the code to the roboRIO i got the following error:
BUILD FAILED
C:\Users\East\wpilib\java\current\ant\build.xml:69 : Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK.
It is currently set to "C:\Program Files\Java\jre1.8.0_25"
Can someone give me a hand in fixing this? <3
Unread 04-02-2015, 15:06
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: Problem Downloading Code to Robot
BUILD FAILED
You need to have a jdk installed on your computer to compile your code. You can download the latest jdk from here.
Unread 04-02-2015, 15:53
wolverines wolverines is offline
FRC #5596
wolverines is an unknown quantity at this point
Hello,
I also have the same problem with my computer. I can download code to the RoboRio inky from my classmate computer that was given to me by FRC. When I try any other computer I am unable to connect to the Rio. I have tried many different ways of solving this problem but none have worked. Please HELP!
Unread 05-02-2015, 09:04
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
Rookie Year: 2012
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Originally Posted by wolverines View Post
Hello,
Can you post your error message here when you compile, anthonygraff24's error is because he doesn't have the correct java installed so his computer cant compile to the code. But the process of compiling and sending the code to the robot can be very complex and has a lot of failure points, without your exact error message it will be really to pinpoint your exact problem.
