Go to Post Honestly, no one at a FIRST competition is gonna judge you. Chances are, there are least 20 people dorkier than you. - JohnnyB [more]
Unread 04-02-2015, 18:09
TBots TBots is offline
FRC #3350
TBots is an unknown quantity at this point
How to Use LaunchPad MSP430 in combination with Labview
We need a way to increment our winch system, so that by the push of a button, the cable connected to the winch goes up a particular degree. Is there a way to use the LaunchPad to complete this task in combination with labVIEW? If there is a way to complete this using only labVIEW, that is just as great. Any information regarding how to complete this, would be fantastic!
Also. If the LaunchPad is connected to the winch system, how do we control it with a joystick? Is there a way to connect it through the D-LINK?
Thank you for any help you can bring us.
Unread 04-02-2015, 18:15
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
Re: How to Use LaunchPad MSP430 in combination with Labview
I don't really understand what you are trying to do.
It sounds like you are trying to use the Lauchpad on the robot to control winch from a computer with a joystick. If you are trying to do this on an FRC robot, it is illegal because all motors have to be controlled by the roboRIO, and I also don't see a reason for it.
If you are doing it just for testing, you need to write code for the Launchpad in C++ using Energia (AFAIK you can't program Launchpads in LabView). I'll explain it more if this is actually what you want.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 04-02-2015, 21:19
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If you want to be able to run a motor so that a mechanism moves to a desired location, you will need to have some way of measuring the mechanism's location. Depending on the details of the mechanism, it can be easy in LabVIEW to control a motor based on sensor values.
If there's a pivot point for something that moves along with the "cable connected to the winch", you can use a potentiometer or other absolute angle sensor as feedback to the roboRIO. If there's a limited range of linear travel, you can use a "string pot". You can use a rotary encoder to measure the number of degrees the winch has turned, and if you can ensure that you always know where the winch starts, that will let you know where it is at all times.
Unread 04-02-2015, 21:28
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Building on what Alan has already said, you also asked about using the LaunchPad.
Alan is correct in that you will have to use LabVIEW to control the motors, while also reading the feedback from the mechanism being moved. The feedback will be in the form of counts from an encoder, voltage from a pot, etc, etc.
The LaunchPad is intended to be used as a HID device on the driver station. Using it as such, you can assign buttons attached to it's digital inputs to be recognized in LabVIEW and move your lift accordingly.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
