Go to Post FIRST builds bridges, and absolutely should not build walls. - Jacob Bendicksen [more]
Unread 04-02-2015, 18:22
Team3220's Avatar
Team3220 Team3220 is offline
Mechanic of Mayhem
FRC #3220 (Mechanics of Mayhem)
Rookie Year: 2013
Team3220 is an unknown quantity at this point
frc error 44061 loop/relay troubles
We are using the default mecanum with arm 2015 code, and we have added some relays (probably incorrectly). Whenever we drive the robot, it operates perfectly fine, with a working camera, but we get the infamous "Error 44061" every few seconds, over and over again, during TeleOp. I probably coded the relays wrong, as they perpetually run backwards, despite being assigned to buttons. What should we do? Can anyone help me with my relay/error troubles? I can post pictures of our begin/teleop VIs, if you think it will help.
Thanks!
Unread 04-02-2015, 19:41
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: frc error 44061 loop/relay troubles
It's easiest on us if you can zip and post the project.
Unread 06-02-2015, 14:52
Team3220's Avatar
Mechanic of Mayhem
Rookie Year: 2013
Here's our TeleOp code. It's us giving an error saying Relay DevRef isn't wired.
Unread 06-02-2015, 15:03
Just Itinerant
Not enough to go on for the DevRef without the rest of the project.
However, what you posted does have a bunch of errors highlighted by all the red dots.
All the enumerated types used aren't the right ones for Relay.
Get one correct Relay Enum by
  • Deleting the wire into Relay (the one with the red dot)
  • Right-click on the now vacant Relay input node and choose Create->Constant
That's the correct Relay enum type.
  • Now make copies of the correct one and replace all the others
  • Finally, remove the Enum you created into Relay and wire Relay into the Select as it was before.
  • If done correctly all the red dots should be gone.
P.S.
What are you using this Relay for?
Forward, Reverse, Off are an unusual combination unless they're LEDs or something like that.
Unread 06-02-2015, 15:08
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
It looks like you are using a RefNum Set instead of a RefNum Get. You'll only use the set (arrow going into the hashtag) in Begin.vi. You'll use the Get (arrow going away from the hashtag) in any other vi you want to use the device in.
I'm right 90% of the time, so why worry about the other 3%?
Unread 06-02-2015, 15:10
Team3220's Avatar
Mechanic of Mayhem
Rookie Year: 2013
This is the code you gave us in another thread. We copied it. And yeah we fixed the Set/Get issue.....my bad xD
Unread 06-02-2015, 15:16
Just Itinerant
Cecil (aka Alex) caught it!
Unread 06-02-2015, 17:24
Team3220's Avatar
Mechanic of Mayhem
Rookie Year: 2013
Haha okay. And we're using this to raise/lower an arm to pick up the crates. We're using spike relays to control window motors that raise/lower the arm via a winch. I can post pictures, if you're (understandably) having problems understanding my vague description. Also, I changed my code to match your (Mark's) description. Still an error on the second comparison, but hopefully I can fix that this weekend.
Unread 06-02-2015, 21:27
Team3220's Avatar
Mechanic of Mayhem
Rookie Year: 2013
Never mind- I fixed it. Thank you all!
Name:	Relay Update.PNG
