Go to Post FIRST is not all about the competitions. FIRST is about what you learn to get to wherever you got to, whether that be first seed or last. - StephLee [more]
Unread 04-02-2015, 18:56
FRC2501's Avatar
FRC2501 FRC2501 is offline
FRC #2501 (Bionic Poalrs)
FRC2501 is an unknown quantity at this point
FRC Team 2501 Electronics Box
This year we decided to go sleek and simple and our Electronics Team drafted up a plexiglass box, laser cut it and fit all of our electronics in it. The idea is to easily take all the electronics off the robot quickly if something breaks/shorts (we had a fair share of that last year).
All the external motors connect to the box via Anderson Connectors, and the smaller components via PWM connectors.
ID:	18146  Click image for larger version
ID:	18147  Click image for larger version
ID:	18148  Click image for larger version
Unread 04-02-2015, 19:08
wyrzykowskij1's Avatar
wyrzykowskij1 wyrzykowskij1 is offline
FRC #2851 (Crevolution)
wyrzykowskij1 is an unknown quantity at this point
Re: FRC Team 2501 Electronics Box
Looks really good. Just make sure that the field personnel can easily see the indicator lights on your D-link when it's in your robot. Also, why did you decide to go with a wood bottom rather than plexiglass or Lexan?
Unread 04-02-2015, 19:19
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Is that Plexiglas (acrylic) or polycarbonate (Lexan/Makrolon)? You do not want to use acrylic on your robot.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 04-02-2015, 19:20
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Rookie Year: 2012
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Originally Posted by 2015 FRC Manual Section 4.7, Table 4-1, Row 11
Motor name: Hard drive motors or fans that are included in the 2015 Kickoff Kit, 2015 FIRST Choice, are
a part of a legal motor controller (including manufacturer provided accessories), or COTS
computing device
Max Qty Allowed: unlimited
While that may be a COTS fan intended for using with a computing device, it's not part of a COTS computing device you are using on the robot. However, having some type of high powered air circulation device for use in the pits might be a good idea, especially during the playoffs.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 04-02-2015, 19:25
MrRoboSteve MrRoboSteve is online now
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Nice work! I like the lighting.
Make sure your radio isn't buried too far down in the robot.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 04-02-2015, 19:26
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
I think the fan would be legal if it was not a light up computer fan, but instead the similar one from FIRST Choice: http://firstchoicebyandymark.com/fc15-117
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 04-02-2015, 19:27
Woolly's Avatar
Programming Mentor
Rookie Year: 2012
Yes, the FIRST Choice fan would be legal.
Unread 04-02-2015, 20:03
FRC2501's Avatar
I will swap out the fans. We have a TON of the FIRST Choice fans. Thanks for the tip!
Unread 04-02-2015, 20:09
FRC2501's Avatar
The D-Link is easily seen, there won't be anything blocking it from view on the robot. I used wood on the bottom because it's easier for mounting, so it won't warp or crack with all the electronics on it and so we could save some money.
Unread 04-02-2015, 20:34
FRC2501's Avatar
It's ¼" acrylic.
Unread 04-02-2015, 20:45
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Originally Posted by FRC2501 View Post
It's ¼" acrylic.
You might be fine this year because of the lack of intentional robot contact, but I'd highly recommend using polycarbonate in the future. Anywhere from .09-.125" is fine for FRC non-structural use. The stuff pretty much just doesn't shatter, and takes a lot more abuse than acrylic can. Oh, and did I mention it won't shatter into those nice expensive electronics?
On another note, that's a pretty cool design. If you heed the warnings about placing your radio somewhere where it's easy to see, you seem to have a great design on your hands for an electronics board. Good luck at competition!
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 04-02-2015, 22:27
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Am I missing something with all the electrical layouts I've seen this year (including from my own team)?
The PDB is designed as a "fishbone" pattern, with the mains power coming in at one end, specialty stuff at the other end, and power splitting out to either side.
Why haven't I seen a design that has talons (or other motor controllers) on both sides of the PDB? This design also has CAN crossing from (in the one shot that shows the whole board) from lower right to upper left, and PWMs (and RSL) crossing from upper right to lower left.
I'm also encouraged by the low number of Analog In and DIO ports I've seen populated. We're using all four Analogs on the R-RIO, and at least six of the DIO's for sensors, with backup plans for a few more if the camera code doesn't mature in time. I'm convinced that this game (up to the regional championship level, at least, possibly as far as entree into Einstein) goes to tams that gain speed through automation and smart use of sensors. Whether we get there remains to be seen (only one of our programmers has contributed notably to our code base in previous years), but as a programming mentor this year, I'm spending most of my time making sure that we have the sensors we will need to have a fighting chance; our other programming mentor (who has been working programming our whole time as a team) is doing most of the training. Of course, both of us are giving lots of advice.
