Go to Post I guess we'll just have to resort back to our original plan of telepathy. - seg9585 [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 04-02-2015, 22:05
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
Vex Pro #25 Chain Master Link Source
The Vex Pro #25 chain requires a weird master link with longer pins and thicker side plates. A master link that meets the ANSI standard doesn't work, but we aren't sure exactly what the heavy-duty master link is. We have a master link that's classified as "heavy duty" on the package, but meets the ANSI standard. Vex's heavy duty master link does not.
Vex is out of stock of the heavy duty master link. Where can we purchase a master link that will work with the vex chain?
Unread 04-02-2015, 22:12
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: Vex Pro #25 Chain Master Link Source
Team 221 sells a Dark Soul chain tool for #25 chain. It's available from a few different suppliers online. It allows you to break and rejoin chain without any master links; we use it all the time now. Why not contact vex about the strength of the master link?
Unread 04-02-2015, 22:16
Owen Busler's Avatar
Owen Busler Owen Busler is online now
Build Captain
FRC #0303 (Test Team)
Team Role: Leadership
Rookie Year: 2014
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
Although it is much more difficult, it is worth it in the long run just to re-assemble the chain. This is usually done with the flip side of a chain breaker. A tool like this works well:
http://www.team221.com/viewproduct.php?id=70
Unfortunately it is out of stock
Good luck with the rest of your season.
Unread 04-02-2015, 22:18
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
We actually have had a harder time with master links than with the tool, espcially the thin c-shaped plate that always seems to get lost.
Unread 04-02-2015, 22:30
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Hmmm this is very concerning. I haven't used 25 chain before sadly with this year being my first. I've been so used to ordering 35 chain from AndyMark or Vex and getting masterlinks from either AM or McMaster so I went about 25 the same way with 25 chain from Vex and master links from McMaster (because they were out of stock at Vex). I'm only now noticing the disclaimer that only the master links below (which are conveniently out of stock) work with Vex chain.
We were hoping to do assembly this Friday and over the weekend so would that mean my next best bet is to order chain from McMaster? I need close to 120ft so $5 per foot is robbery compared to $1 per foot from Vex.
Any concerns about using Vex sprockets with other sourced chains?
Insert panic.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 04-02-2015, 22:35
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Insert panic.
Andymark #25 works fine with McMaster master links, and is only slightly pricier than Vex chain.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 04-02-2015, 22:58
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
http://www.therobotspace.com/Product...e=vex-217-2998
Unread 04-02-2015, 23:03
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
Originally Posted by Michael Hill View Post
Awesome, thanks!
Unread 04-02-2015, 23:09
Originally Posted by s_forbes View Post
Awesome, thanks!
Since you're in Arizona, West Coast Products might be a quicker choice: http://www.wcproducts.net/roller-chain
Unread 04-02-2015, 23:11
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is offline
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
http://www.electricscooterparts.com/chain25.html
Unread 04-02-2015, 23:24
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
#25H master links from other sources work on our stuff as well, nothing super special about ours.
-Aren
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 05-02-2015, 12:37
AKA: Brendan Browne
Figured this could help someone else out. I found what looks like the same chain break as the ones from 221 shipping out of Utah.
Just got off the phone and they are sending that out today.
http://www.davesmotors.com/s.nl/it.A/id.2258/.f
Unread 05-02-2015, 12:50
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
use coupon code DDM for 5% off.
Always google for coupon codes before ordering is a nice trick someone told me.
