Go to Post a good team can do almost anything - Wayne C. [more]
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Unread 04-02-2015, 23:12
BananaKing1378's Avatar
BananaKing1378 BananaKing1378 is offline
BaNaNaK1Ng8o8
AKA: Banene
FRC #1378 (Hilo Banana Robotics)
Team Role: Human Player
BananaKing1378 is an unknown quantity at this point
PID Controller class not calculating output value
Hello! So to get to the point, the PIDController we are using is not calculating an output value.
We set the controller to read input from an encoder and output to a talon. In the code it looks like this:
LiftControl (0.1, 0.1, 0.1, &EnTwoSim, &TwoSim);
We followed example given by the WPILibrary website. We want the PID to basically hold the lift at a position when the driver has stopped pushing the button to move the lift. We thought to accomplish this by making the setpoint of the class to be equal to the encodervalue. This would make the error small by nature but the PID should make the motor "fight" against forces pushing against it by design.
We printed the value of the error, encoder value, setpoint, and output value to the dashboard. As expected the error is small, and the encoder value and setpoint are close. However, the output value remains at 0. I have tried to set the minimum and maximum output values but that did nothing. I looked at the PIDController class and saw that there is a protected function that calculates the output but it can only be accessed by a "Notifier" that is created when the PIDController object is initialized.
Anyway, I hope this wasn't too confusing and would greatly appreciate any help we could get on this issue. Thanks!
Unread 04-02-2015, 23:59
mmaunu's Avatar
mmaunu mmaunu is online now
FRC #2485 (W.A.R. Lords)
Rookie Year: 2010
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
Re: PID Controller class not calculating output value
Hello!
Without looking at the actual code, I am going to make a guess...but could you post the code in question? I am assuming that you are using a PIDController object.
Did you enable the PIDController object? The API has an enable method and a disable method so that you can turn the controller on and off. It is not enabled by default. When the operator lets go of the button, enable the controller; disable it when the button gets pressed so that the lift can move to a new position. Or, alternatively, you can have another button that sets a predetermined setpoint so that this new button starts automatically taking the lift to a new position.
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
