Go to Post mabye this is a case of I AM JVN to the Extreme! - Tytus Gerrish [more]
Unread 05-02-2015, 09:41
FRC2501's Avatar
FRC2501 FRC2501 is offline
FRC #2501 (Bionic Poalrs)
FRC2501 is an unknown quantity at this point
TalonSRX invert?
We program in C++ and I was wondering if there is a way to invert TalonSRXs in programming because out Omni drive needs both right motors to be inverted or it acts weird
Unread 05-02-2015, 10:14
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is offline
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
Re: TalonSRX invert?
I wouldn't recommend inverting the speed controllers. Just make sure your math takes into account the the fact that your right motors need to rotate in the opposite direction and invert the signal you're sending it.
LeftMotor.set(1)
RightMotor.set(-1)
Unread 05-02-2015, 10:41
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I think you're looking for the setInvertedMotor() function. It works with any Robot Drive object regardless of what kind of speed controller you have on your drivebase.
Unread 05-02-2015, 16:29
FRC2501's Avatar
The SetInvertedMotor() function seems to be broken to me, it doesn't like either
Code:
driveSystem.SetInvertedMotor(kFrontRightMotor, true);
or
Code:
driveSystem.SetInvertedMotor(rightFrontDriveTalon, true);
Unread 05-02-2015, 16:45
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Code:
or
Code:
Lowercase "s"? setInvertedMotor
Unread 05-02-2015, 17:07
FRC2501's Avatar
I looked in the RobotDrive.h and it is a capital S, the error I get is that it isn't a Motor Type
Unread 05-02-2015, 17:25
baumgartensam's Avatar
baumgartensam baumgartensam is offline
AKA: Sam Baumgarten
FRC #0751 (Barn2Robotics)
Rookie Year: 2013
baumgartensam will become famous soon enough
A number of the method names are capitalized. It drives me crazy (pun intended) as the Java naming convention is a lowercased first letter and then the rest of the word is camel cased. The CANTalonSRX class has a few of these incorrectly named methods as well but it's a fairly minor issue in the scheme of things.
Unread 05-02-2015, 18:03
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Code:
or
Code:
Unless you have using statements, I believe you need to qualify the constant names:
Code:
driveSystem.SetInvertedMotor(RobotDrive::kFrontRightMotor, true);
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 05-02-2015, 18:26
FRC2501's Avatar
Code:
Thanks! It now works
