Go to Post So go out and start thinking outside of the KOP. - ChrisH [more]
Unread 02-05-2015, 12:46 PM
AnnaliseDonavan AnnaliseDonavan is offline
FRC #4284
AnnaliseDonavan is an unknown quantity at this point
Exclamation Java - "debug as " problem
When I run my program through the "debug as" and then " WPIlib Java Deploy " the code makes eclipse become "responding" or (Not Responding)
I created this program off of the "getting started" program that comes with the FRC project
package org.usfirst.frc.team4284.robot;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.buttons.JoystickButton;
import edu.wpi.first.wpilibj.buttons.Button;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
RobotDrive Drive;
Joystick drivestick;
Joystick xbox;
int autoLoopCounter;
* This function is run when the robot is first started up and should be
* used for any initialization code.
public void robotInit() {
Jaguar FL = new Jaguar (1);
Jaguar BL = new Jaguar (2);
Jaguar FR = new Jaguar (3);
Jaguar BR = new Jaguar (4);
Drive = new RobotDrive(FL,BL,FR,BR);
drivestick = new Joystick(0);
xbox = new Joystick(1);
* This function is run once each time the robot enters autonomous mode
autoLoopCounter = 0;
* This function is called periodically during autonomous
/*if(autoLoopCounter < 100) //Check if we've completed 100 loops (approximately 2 seconds)
Drive.drive(-0.5, 0.0); // drive forwards half speed
autoLoopCounter++;
} else {
Drive.drive(0.0, 0.0); // stop robot
* This function is called once each time the robot enters tele-operated mode
public void teleopInit(){
Button button1 = new JoystickButton(xbox, 1),
button2 = new JoystickButton(xbox, 2),
button3 = new JoystickButton(xbox, 3),
button4 = new JoystickButton(xbox, 4),
button5 = new JoystickButton(xbox, 5),
button6 = new JoystickButton(xbox, 6),
button7 = new JoystickButton(xbox, 7);
button1.whenPressed(new ElevatorReverse());
button2.whenPressed(new ElevatorOn());
button3.whenPressed(new ElevatorOff());
button4.whenPressed(new ArmsOut());
button5.whenPressed(new ArmsIn());
button6.whenPressed(new ArmsVerticalIn());
button7.whenPressed(new ArmsVarticalOut());
* This function is called periodically during operator control
Drive.arcadeDrive(drivestick);
* This function is called periodically during test mode
public void testPeriodic() {
LiveWindow.run();
Unread 02-05-2015, 01:04 PM
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
Re: Java - "debug as " problem
What happens if you wait a little while? On my computer, it freezes for around 5-7 seconds and then starts working again. I think this might be due to having to connect to the roboRIO over the network.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
