Go to Post I saw Dave Lavery on the Webcast. And he winked at me! - Tetraman [more]
Unread 05-02-2015, 16:18
TheTurtleofDoom TheTurtleofDoom is offline
FRC #2988
TheTurtleofDoom is an unknown quantity at this point
What do the Swigtype classes do in the WPI, I have looked at the documentation
http://first.wpi.edu/FRC/roborio/rel...a/classes.html is where I looked for the documentation, googling wpilibj swigtype had one result.Anyone know what they do?
Unread 05-02-2015, 16:27
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: What do the Swigtype classes do in the WPI, I have looked at the documentation
Did you try just searching "Swigtype"?
While I am not 100% sure, I believe Swigtype is referring to this:
http://www.swig.org/
Is there anything specific you are trying to do with them?
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 05-02-2015, 16:40
FRC #2988
No I didn't google that, and no I'm not trying to do anything with them, just saw the classes in the api and didn't know what they did, and couldn't find out anything about them.Thank you for this illuminating post.
Unread 05-02-2015, 17:28
baumgartensam's Avatar
baumgartensam baumgartensam is offline
AKA: Sam Baumgarten
FRC #0751 (Barn2Robotics)
Rookie Year: 2013
baumgartensam will become famous soon enough
I just dove into the source and the header for all the files named SWIGTYPE_* is:
Code:
 * This file was automatically generated by SWIG (http://www.swig.org).
 * Version 2.0.11
 * Do not make changes to this file unless you know what you are doing--modify
 * the SWIG interface file instead.
Not sure what they are for but they are definitely associated with http://www.swig.org. The uses also seem very strange. Brad Miller will probably have a better explanation
UPDATE:
"SWIG is an interface compiler that connects programs written in C and C++ with scripting languages such as Perl, Python, Ruby, and Tcl." Maybe it has to do with the cross-compilation of wpilib?????
Unread 05-02-2015, 18:11
James Kuszmaul James Kuszmaul is offline
NEFIRST CSA
FRC #0971 (Spartan Robotics)
Rookie Year: 2011
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
In order to use certain HAL classes (written in C++) in the Java portion of WPILib, we create JNI bindings for those classes/functions. In the case of the new Talon SRX, we used swig to generate the JNI bindings for the CanTalonSRX class and then wrapped that with the CANTalon class. Those odd SWIGTYPE* classes are how swig handles c pointers in the JNI bindings. Teams should not need to use any of the swig-related classes; the CANTalon wrapper should implement all the necessary features.
FRC971 (Student) 2011-2014
FRC190 (College Mentor-ish) 2014
WPILib Development 2014-present
