We run this code:
Code:
private:
//Initializing livewindow
LiveWindow *lw;
//Initializing stick
Joystick *stick;
//Initializing the Chassis parts
Talon *kFrontLeftMotor;
Talon *kFrontRightMotor;
Talon *Elevator;
RobotDrive *robot;
Relay *Fan;
DoubleSolenoid *shifter;
Encoder *ChassisEnc;
Encoder *OtherEnc;
Encoder *ElevatorEnc;
//Initializing the values for Cheesy Drive
float Rotation;
float Acceleration;
float rightMultiplier;
float leftMultiplier;
double automode;
Gyro *gyro;
bool robottime;
double Angle;
DoubleSolenoid *ElevSol;
bool robotdrive;
double Kp = 0.03;
DigitalInput *Limit;
PIDController *ElevatorPID;
void RobotInit()
SmartDashboard::init();
lw = LiveWindow::GetInstance();
stick = new Joystick(0);
kFrontLeftMotor = new Talon(0);
kFrontRightMotor = new Talon(1);
Elevator = new Talon (2);
robot = new RobotDrive(kFrontRightMotor, kFrontLeftMotor);
Fan = new Relay (3);
/* Setting the shifter as a DoubleSolenoid
* Because we're using both pistons off of
* one Double Solenoid
shifter = new DoubleSolenoid (0,1);
ChassisEnc = new Encoder (0,1, false, Encoder::EncodingType::k4X);
OtherEnc= new Encoder (8,9, false, Encoder::EncodingType::k4X);
//Setting it so the fan is off by default
Fan->Set(Relay::kOff);
//Setting the Rotation and Accel values
Rotation = stick->GetRawAxis(1);
Acceleration = stick->GetRawAxis(3);
/*Setting the multipliers
* so that they don't allow
* a robot to go full forward
* while going full turn
rightMultiplier = Rotation + Acceleration;
leftMultiplier = Rotation - Acceleration;
//Setting the shifter to Low Gear
shifter->Set(DoubleSolenoid::kReverse);
robot->SetInvertedMotor(RobotDrive::kFrontLeftMotor, true);
robot->SetInvertedMotor(RobotDrive::kFrontRightMotor, true);
ChassisEnc->SetDistancePerPulse(.084);
OtherEnc->SetDistancePerPulse(.084);
ElevatorEnc->SetDistancePerPulse(.5);
gyro = new Gyro (1);
Angle = gyro->GetAngle();
if (stick->GetRawButton(1))
automode = 1;
if (stick->GetRawButton(2))
automode = 2;
} else {
automode = 0;
SmartDashboard::PutNumber("Auto:", automode);
gyro->InitGyro();
ElevSol = new DoubleSolenoid (2,3);
gyro->InitGyro();
Limit = new DigitalInput(2);
ElevatorPID = new PIDController(0.5, 0.0, 0.0, &ElevatorEnc, &Elevator);
We get this error: no matching function for call to 'PIDController:
IDController(double, double, double, Encoder**, Talon**, double)'
We're confused on how to get the function for the PID working. Thanks!
