Thread Tools |
Rating:
Display Modes |
What's your plan for Autonomous?
We have a very hopeful plan where we get our alliance mates to simply move to the autozone, then we'll stack the totes and put all three bins in the autozone in one 13-second sweep. It works fine in the model we made... but we all know how that can go astray.
So, what's everyone planning to do during auto? Take care of your own bin and tote? Just move the bot? Something bigger? |
Re: What's your plan for Autonomous?
We have many possible autonomous modes included in our code... We will choose depending on our allies and change it from our driver station... Here's a couple of examples :
1. Move forward (with a selector for the distance) 2. Don't move (if we have any problem on the robot or if an alliance wants to do something special) 3. Take a container and move forward 4. Take a container, move forward and put it down And every other possibility you can't think about... We coded a nice looking dashboard showing which auto mode is in use, its description and where to place the robot on the field... |
Try to get as many green bins from the center step into our side of the field as possible. Assuming our alliance can stack totes the bins really can add to the score.
Use sensors to collect data about the surrounding environment, then discard it and drive into walls.
I think we're going to be moving. Not sure exactly what we'll be moving... |
score points.
We do plan to have multiple autonomous routines, so we can adapt to our alliance.
We have 2 modes this year.
1) drive forward (push a bin with us?) 2) grab bin 1, grab 3 yellow totes and stack, set bin 1 down (not tall enough to put on top of the stack) |
#10
We plan on doing a 3 tote stack and 3 container set then pull all 4 containers off of the step and line up at the HP station for our full field stacking mechanism. And that's just the first 5 seconds of autonomous.
#11
And then, the robot builds ten stacks of grey totes and, during the last seven seconds, it deploys a wall to block incoming litters...
#12
Anyways, we plan to a set of switches to select between modes. While I'm not the programming team, I think/hope it will include: do nothing drive forward grab a tote or container and drive it to the auto zone grab the three yellow totes for a tote stack after our partners move two recycling containers out of the way (maybe, this is kind of a stretch goal). |
#13
Sounds like you've had a rough day at work recently.
#14
We took a really bold strategic decision to spend our autonomous period making contributions to our alliance's efforts to get high scores.
#15
Well, at least that makes "Do nothing" look like an improvement!
