Go to Post You can either spend lots of energy complaining about it and whining or you can try to figure out how to make a positive experience from the whole thing. - dlavery [more]
Unread 06-02-2015, 00:45
majesticfish majesticfish is offline
AKA: Sean Yu
FRC #0948 (NRG)
Rookie Year: 2011
majesticfish is an unknown quantity at this point
SmartDashboard Command Bugging Out
Hi everyone,
I recently wrote a PID turn command that takes PID values from preferences on a Java SmartDashboard. I put this command to the SmartDashboard in teleopinit. However sometimes when i run the command through the smart dashboard, the button bugs out. The button seems to be quickly alternating between "Start"(green) and "Cancel"(Red). Even when I disable the robot, the button is still bugging out. However, when I try to reload the robot code, the command seems to be working again. Has anyone else experienced this problem?
Sean
