Go to Post How many programmers does it take to change a light bulb? None. They'll just say it's a hardware problem. - crafty [more]
Unread 06-02-2015, 00:55
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
Team Role: Coach
Rookie Year: 2012
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
carpet_ recycling containers
Anyone have any info on how well or poorly recycling containers will slide when pushed across "official " carpet? The carpet we have have done it on doesn't work well
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 06-02-2015, 07:32
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: carpet_ recycling containers
The bottom of the recycle bin has a circular fitting made to screw into a larger ground platform. The circular part has a saw-tooth edge that should dig into the carpet pretty well when just pushed.
Unread 06-02-2015, 07:51
kbrowncny's Avatar
kbrowncny kbrowncny is offline
Mechanical Engineering Mentor
AKA: Kevin Brown
FRC #2168 (Aluminium Falcons)
kbrowncny is an unknown quantity at this point
Run a science experiment to figure out the coefficient of friction. We had some of our students attach carpet to a piece of plywood, place the totes on there and tilt the plywood until they broke static friction. For the totes its about a 0.5 coefficient. Try it for the bin, its a neat way for students to apply what they learned in physics class. They were using this info to figure out how much force we needed to apply to our intake to grip the totes.
Unread 06-02-2015, 14:54
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
You may have to put some weight in the bottom of the RCs to get this to work - if the COF and COG are both high enough (as I suspect they are), the RC will fall over before it slides.
Unread 06-02-2015, 15:00
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
Team Role: Teacher
Rookie Year: 2011
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
We've found that you can push the RC's across the carpet, but you have to be careful: It's important to contact them a little below their CG and to not apply too much force too suddenly... We are planning on pushing them a little bit - and preferring that they don't fall over.
