Go to Post This is just one example of why you MUST NOT make engineering decisions based on assumptions. You should check/measure your parts and make appropriate design adjustments. - Stu Bloom [more]
Unread 06-02-2015, 17:03
Jeremy2145's Avatar
Jeremy2145 Jeremy2145 is offline
FRC #2145
Jeremy2145 is an unknown quantity at this point
Microsoft Lifecam HD-3000 in Java
What do you need to do to stream the Microsoft Lifecam HD-3000 to the Smartdashboard?
Unread 06-02-2015, 17:19
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
Rookie Year: 2012
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
Re: Microsoft Lifecam HD-3000 in Java
We are running Java and this post helped us. We added the code in robotInit() (Iterative Robot) and we had a Lifecam HD-3000 USB camera image displayed in the standard dashboard while the robot was connected to the driver station, even when disabled.
Unread 06-02-2015, 17:30
Jeremy2145's Avatar
FRC #2145
After adding that into the robotinit() it gives an error on "new CameraServer();" saying that "the constructor CameraServer() is not visible." Any ideas?
Unread 06-02-2015, 17:36
markmcgary's Avatar
Software Mentor
Rookie Year: 2012
It appears that CameraServer is (now) a Singleton class. Try this:
Code:
    	CameraServer camera = CameraServer.getInstance();
    	camera.setQuality(50);
    	camera.startAutomaticCapture("cam0");
-or-
Code:
    	CameraServer.getInstance().setQuality(50);
    	CameraServer.getInstance().startAutomaticCapture("cam0");
Unread 07-02-2015, 11:25
Tyfighter98's Avatar
Tyfighter98 Tyfighter98 is offline
Software Lead
FRC #3255 (Super NURDs)
Rookie Year: 2012
Tyfighter98 is an unknown quantity at this point
This post might help as well. http://goo.gl/gVoLH6
