Go to Post You just have to care enough to give it a try. Your mentors will appreciate the effort. - Koko Ed [more]
Unread 06-02-2015, 20:39
VaneRaklan VaneRaklan is offline
FRC #2557 (The SOTABots)
Rookie Year: 2014
VaneRaklan is an unknown quantity at this point
Pulling Variables from Robot
So we are having some problems with variables in Command base programming. What we want to do is to create a variable in either Robot.Java or Robot.Map (or just any one class) that we can call from (i.e Robot.(variable name)) to be used in a command or subsystem. We just cant seem to be able to do just that. Anyone have any ideas as to why or for how we can do this?
Unread 06-02-2015, 21:34
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Rookie Year: 2012
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Pulling Variables from Robot
In robot map you declare the constants for the robot.
For example:
Code:
public static final int MOTOR_SPOT_1 = 1;
Then in any class simply reference it by typing
Code:
RobotMap.MOTOR_SPOT_1
Unread 06-02-2015, 23:23
defied defied is offline
FRC #2557
defied is an unknown quantity at this point
For example:
Code:
Code:
Would there be a way to change the value during runtime from the command pulling it? Remove final?
Thanks,
D
Unread 06-02-2015, 23:35
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
Rookie Year: 2012
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
D
Yes, removing final will allow you to change the value during runtime.
Unread 06-02-2015, 23:37
FRC #2557
Perfect! Thanks!
D
Unread 07-02-2015, 23:28
Head programmer
Rookie Year: 2012
The final keyword in java is used when a variable value is known at runtime.
