Go to Post I, for one, have no particular problem with singing, dancing and sex appeal. Mark Leon combines all that with a career at NASA! - Rick TYler [more]
Unread 06-02-2015, 22:38
Tyfighter98's Avatar
Tyfighter98 Tyfighter98 is offline
Software Lead
FRC #3255 (Super NURDs)
Rookie Year: 2012
Tyfighter98 is an unknown quantity at this point
USB Camera Solution
After many hours of trial and error we managed to get the USB camera to work while running the Smart Dashboard (Java). All you need to do is create a new project example for Intermediate Vision and delete lines 39, 44, & 45 (just draws a circle on the viewer of the camera). You will have some unused imports so removed those and then just make sure you have created the object in Smart Dashboard and you will be set.
Unread 07-02-2015, 15:54
JavaNoNothing14 JavaNoNothing14 is offline
FRC #2681
Rookie Year: 2012
JavaNoNothing14 is an unknown quantity at this point
Re: USB Camera Solution
how do i create the object for the dashboard? where do i place the line of code?
Unread 07-02-2015, 16:47
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Rookie Year: 2012
Team3266Spencer is an unknown quantity at this point
You add the USB Camera widget in the dropdown in the smart dashboard program.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 07-02-2015, 17:25
Software Lead
Rookie Year: 2012
You can pretty much put the code from the example robot into the Robot.java class. Just pay attention to where each part is location in such as robotInit and what not. There are other ways you can add the code for different results but that is up to the individual teams.
Unread 07-02-2015, 23:10
dominik.daners's Avatar
dominik.daners dominik.daners is offline
Member
FRC #4729 (E.M.U (Experimental Mayhem Unit))
Team Role: Mechanical
Rookie Year: 2012
dominik.daners is an unknown quantity at this point
When you say USB Camera Solution, where do you plug the camera into? The NiRIO?
Also, I have tried using the smart dashboard before without any success (I rage quit), can you give us the line of code required to do this?
thx.
Unread 08-02-2015, 02:37
Software Lead
Rookie Year: 2012
thx.
I am referring to plugging the camera into the roboRIO. And like I said previously, just create the intermediate vision example project and delete the lines of code I listed in the root post.
Unread 08-02-2015, 02:42
Member
Rookie Year: 2012
Just figured out what you meant my the intermediate image project. thx. I'll give it a a go.
Unread 08-02-2015, 16:27
daneelshof's Avatar
daneelshof daneelshof is offline
Programming Mentor
FRC #1619 (Up-A-Creek Robotics)
daneelshof has a spectacular aura aboutdaneelshof has a spectacular aura about
This seems to be working for us! We're using the command-based robot code, so it took a little bit of rejigging to use it.
We're running the image grabbing in Teleop Periodic and only every tenth call. Otherwise we had issues with not sending CAN commands to the Talons often enough. The frame rate of the camera is extremely low because of this. Anyone have any ideas on improving performance?
Unread 08-02-2015, 17:04
Software Lead
Rookie Year: 2012
I noticed the frame rate issue as well. I know FIRST regulates the amount of data you can send so it may not be possible to improve it.
Unread 14-02-2015, 13:44
schleprock's Avatar
schleprock schleprock is offline
Code Jockey
FRC #4905 (AndromedaOne)
Rookie Year: 2014
schleprock is an unknown quantity at this point
Question Re: USB Camera Solution
we just got some ms lifecam hd-3000 cameras and we're getting an exception thrown from the vision code with no camera output. i'm using the intermediate vision example with the lines indicated in a previous post deleted. the exception is:
Unhandled exception: VisionException [com.ni.vision.VisionException: IMAQdxError: -1074360311: Camera not found] at [com.ni.vision.NIVision._IMAQdxOpenCamera(Native Method), com.ni.vision.NIVision.IMAQdxOpenCamera(NIVision.j ava:24455), org.usfirst.frc.team4905.robot.Robot.robotInit(Rob ot.java:27), edu.wpi.first.wpilibj.SampleRobot.startCompetition (SampleRobot.java:121), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:234)]
does anyone have any suggestions for fixing this?? i'm using the latest eclipse plugin's from wpi.
also i verified that the webcamera is working by plugging it into my laptop and viewing it.
thanks
Unread 15-02-2015, 01:14
Merfoo's Avatar
Merfoo Merfoo is offline
FRC #0955 (CV Robotics)
Rookie Year: 2012
Merfoo is an unknown quantity at this point
thanks
Does the name of the camera that shows up on the roborio web interface match the one that is being supplied in the code? The name of the camera in the code is "cam0", but it may be something else. To find the name of the camera go to "roborio-xxxx.local/" in a web browser where the x is your team numbers, which would be "roborio-4905.local/" for you.
Unread 15-02-2015, 13:33
schleprock's Avatar
Code Jockey
Rookie Year: 2014
because the CameraServer is throwing an exception when it's trying to create the instance there is no "Cam0" or anything else. i had another webcam "sortof" working a few weeks ago, at least it did not throw this exception just a different problem when it tried to stream. i was reasonably sure the problem was no support for that camera. so we bought the "supported" webcam and now i get this exception. my guess is that the latest update to the firmware for the roborio has broken the webcam ability. unless someone else has it working on the newest wpi plugins??
