Go to Post PS: Please use the default font for postings, it is so much easier to read. - DonRotolo [more]
Unread 06-02-2015, 23:59
Addison4300's Avatar
Addison4300 Addison4300 is offline
FRC is love, FRC is life
AKA: Addison
FRC #4300 (The Lion Kings)
Team Role: Leadership
Rookie Year: 2013
Addison4300 is on a distinguished road
Lift cable
So our team is making a lift with a cable attached to a tough box mini to act as a winch system to raise the lift. I see many other teams have this design as well. How exactly are your teams attaching the cables to the motors? every way we try it isn't strong enough to lift anything or it is too hard to attach.
Unread 07-02-2015, 00:04
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Re: Lift cable
Well if you have a spool, you can drill a hole through it (perpendicular to the output shaft of gearbox), and run the cable through it. Once through, get cable end crimps and get a nice and solid crimp on it. Done correctly, that should be all you need. I would counter sink a hole for crimped end to set flush in spool to allow smoother wrapping.
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 07-02-2015, 00:22
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Lift cable
We used this spool for our winch last year. Entirely 3D printed, designed to fit on the hex shaft output from a Vex Pro Ball Shifter. It worked like a champ through 2 week 0, 2 regionals, champs, state fair, an off season, and countless demos. Never had an issue with it or needed it replaced!
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 07-02-2015, 00:34
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Lift cable
As the first two posters indicated, the best way is to pass the cable through a small hole that must rotate with the shaft. If you are planning to wrap the cable directly around the shaft, try adding a wheel hub, passing the cable through one of the bolt holes in the hub, and placing a crimp (or even a knot) behind the hole that's too big to pull through.
Unread 07-02-2015, 02:53
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
Re: Lift cable
There is always silver solder!
Unread 07-02-2015, 03:00
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Lift cable
I agree the best thing is to have a spool and not fasten the cable directly to the gearbox shaft. This is what we did last year. Ignore the rust and lack of cable management.
http://i.imgur.com/W2Z6lOb.jpg
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 07-02-2015, 09:23
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Re: Lift cable
Also, put enough cable so that there is always a wrap around the shaft or spool core. As shown above (or as I described with a hub), you're requiring extra torque at startup, and putting more stress on the mount point than if you had a wrap or two of cable adding their friction to the tug.
Unread 07-02-2015, 09:25
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Re: Lift cable
I hope that was a joke, or meant to be used in conjunction with another means of securing the cable.
Unread 07-02-2015, 11:35
n1ckd2012's Avatar
n1ckd2012 n1ckd2012 is offline
oRyon Labs
AKA: Nick Dulworth
FRC #2587 (DiscoBots)
Rookie Year: 2010
n1ckd2012 will become famous soon enoughn1ckd2012 will become famous soon enough
Re: Lift cable
We drilled a hole in the side wall of our spool, then tied a simple knot around the spool circumference (like the first step in tying your shoes) and passed the end of the cable through the hole in the side wall of the spool. We then swage crimped the end of the cable.
https://plus.google.com/photos/10166...54062264587931
How to swage crimp https://www.youtube.com/watch?v=RfLY6mOBzJ0
Ri3D Team oRyon, 2014-Present
Ri3D 2015: Betelgeuse | Ri3D 2014: Draconis
2587 DiscoBots, 2010-Present
FRC 2012: Laser Dragon, Film, Build Log, Lone Star 3rd Seed Alliance
Vex 2012: Mini Dragon, Film, Math Division Finalists
FRC 2011: DiscoSlide, Film, 118 Parody, Lone Star Regional Finalists
Unread 09-02-2015, 13:45
AKA: Addison
Rookie Year: 2013
Re: Lift cable
Thank you all for the great input!
Unread 09-02-2015, 15:18
RoboChair's Avatar
Re: Lift cable
Silver solder is an amazing way of attaching to most types of cable(not plated) you can just silver solder on a nice neat little eyelet. Or any other fastening method you might wish to use, a bolt might be a great method as well.
Silver solder allows you to "weld" two same or dissimilar metals using a lot of heat. Like brass to stainless steel.
Unread 09-02-2015, 15:59
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Lift cable
Last year we had 2 nails running parallel to our winch shaft. Those two nails held the nylon strap down to the shaft, and they were zip-tied in place on the ends. It's the first time we ever put nails on a robot. It worked well for the short nylon strap, and I'd imagine it would work fine for non-metal cable, like parachute cord. I'll try to remember to snap a photo tonight.
Unread 10-02-2015, 00:50
Ian H. Ian H. is offline
FRC #5026 (Iron Panthers)
Ian H. has a little shameless behaviour in the past
Re: Lift cable
Small enough cable can also fit through set screw holes in a shaft collar. Though not sure how well it would work.
2005-2008 FRC492
2014-Future FRC5026
Unread 10-02-2015, 11:21
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Re: Lift cable
FYI, "silver solder" is a term I have heard used interchangeably with "brazing".
  #15   Spotlight this post!
Unread 10-02-2015, 14:03
Aur0r4's Avatar
Aur0r4 Aur0r4 is offline
Engineering Mentor
AKA: Jim Browne
None #1058 (PVC Pirates)
Aur0r4 has a spectacular aura aboutAur0r4 has a spectacular aura about
Send a message via AIM to Aur0r4
Re: Lift cable
Every crane I've ever seen includes operating instructions to leave multiple turns of wire rope on the hoist drums...usually more than 3, sometimes as high as 9. This allows almost all of the force transfer to occur via friction and your mechanical connection doesn't see hardly any load.
We usually drill through the side of a drum and drill/tap a bolt and put an eye in the cable with a swege that goes around the bolt.
Another tip for spooling cable from the crane world is what we call "lagging". Basically, have your lathe team grind a radiused cutter that matches your cable and then turn the surface of your drum with a shallow spiral groove that matches how the cable would spool on it neatly. This helps it do so.
Good luck!
Jim Browne, EIT
Team 1058 - PVC Pirates
Cianbro Corporation
Construction Structures Engineer
