Dart Potentiometer Wiring
My team just got a Dart Linear Actuator and sensor kit but be can't figure out the wiring for the potentiometer.
Re: Dart Potentiometer Wiring
The pot has three connectors that should be marked on the case as to what each is.
1 & 3 connected by a wavy line should be ground and power. The order only changes the direction of the pot.
So 1=ground & 3=power might mean that turning counter-clockwise increases the signal, while 3=ground & 1=power would be the opposite and clockwise increases the signal. 2 should then be the signal. Does the pot have a make/model #? Last edited by Mark McLeod : 07-02-2015 at 10:41. |
The connections are labeled 1,2, and 3 and a wavy line connecting 1 and 3 but there is no clear indication of what is ground and power.
The brand is Bourns the part number is 3590S-2-201L
So yea,
power on 3 instead would be CW (clockwise) increasing In the schematic, the signal contact slides from left to right when the pot shaft is rotated clockwise. So if 1 is ground, the signal when close to ground will read 0 and will increase as it moves right (CW shaft rotation). If 3 is the ground, the signal when close to power will read nominally 5v (~4.8) and decrease as it moves right (CW shaft rotation) and gets closer to the ground. Last edited by Mark McLeod : 07-02-2015 at 10:54. |
