Go to Post FIRST competitions are a microcosm of real world engineering projects. - KenWittlief [more]
Unread 07-02-2015, 11:53
crollison crollison is offline
AKA: Chris Rollison
FRC #4809 (Black Knight Robotics)
Team Role: Coach
crollison is an unknown quantity at this point
Dual Acting Cylinder used as a single
Is it legal to use a dual acting cylinder as a single? We would like to let gravity handle the return of the piston instead of air. I wouldn't think this would be any different than a spring loaded cylinder. I can't find anything in the rule book that says so.
Thanks.
Unread 07-02-2015, 12:25
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Rookie Year: 2010
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Dual Acting Cylinder used as a single
If the rules don't prohibit something, then it is legal.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 07-02-2015, 12:27
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
There are minimal rules governing plumbing of pneumatics, other than the type of tubing used. If the cylinder meets spec, you should be good.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 07-02-2015, 18:04
Chris is me's Avatar
AKA: Pinecone
Thanks.
This is definitely legal. Teams have done this many times in years past, and nothing in the rules changed this year to imply this wouldn't be legal. In many cases it's a smart way to save air. You're good.
Unread 07-02-2015, 20:04
AKA: Chris Rollison
Team Role: Coach
Thanks all, went from flipping out this morning b/c not enough air to everything is great.
Unread 08-02-2015, 08:45
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Not a legal issue, but a reliability issue. Ensure that you have enough return force that you don't end up with the piston getting "stuck" in one position. Also consider situations in which something falls into the wrong place - with a dual-acting cylinder, you have a bit more capability to work the piece free.
If you have enough ports and valves available, you may want to consider using separate solenoid valves for the two cylinders, so you can use this only when needed. If you want to do this using the FRC-standard solenoid valves, plug the unused "A" or "B" ports so you aren't dumping air from your tanks when you're dumping air from the cylinders.
Unread 08-02-2015, 20:14
2508electronics 2508electronics is offline
The One Man Electrical Team
FRC #2508 (Armada Robotics)
Team Role: Electrical
Rookie Year: 2013
2508electronics is an unknown quantity at this point
One way to get the cylinder to go back is to connect it to one side of a solenoid and connect another (probably smaller) cylinder to the other solenoid output. That is how my team got our catapult from last year's game to come back. We did this because having the cylinder completely controlled with the solenoid created too much resistance. I would also recommend removing the tubing connectors that you will not need if you are trying to get it to move as fast as possible. No issues during inspections!
