Go to Post The terror level was lowered to MOE green for this event. - AdamHeard [more]
Unread 07-02-2015, 15:11
DBaleta DBaleta is offline
FRC #2001
DBaleta is an unknown quantity at this point
Compressor
Do we need to program the compressor in Labview? Is the compressor already programmed into the coding of the double solenoids?
Unread 07-02-2015, 15:14
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
Re: Compressor
When you open a solenoid, the compressor start running (and stops when it fills the tanks) automatically.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 07-02-2015, 15:36
FRC #2001
Re: Compressor
So all i need to do is program the solenoid in the Begin vi, Telop vi, and the Finish vi, and when I do this the compressor will automatically turn on and stop without manually programming it to do so?
Unread 07-02-2015, 16:12
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Compressor
Yes, just so.
If you want to see how it's done, double-click on the Solenoid Open and looking at the block diagram you'll see the compressor Open.
Unread 07-02-2015, 16:19
FRC #2001
Re: Compressor
We've added 2 double solenoids to our program and the compressor does not start. we added the compressor to the Begin vi and tested it and still no compressor. Attached is a copy of our coding in Begin and Telop that pertains to the compressor.
Name:	SW AM Begin.png
ID:	18191  Click image for larger version
Name:	SW AM Telop.png
Unread 07-02-2015, 16:26
Just Itinerant
Re: Compressor
The enums in Teleop are incorrect for Relay. That's why they have red dots.
Get a correct Relay Enum by
  • Deleting the wire into Relay (the one with the red dot)
  • Right-click on the now vacant Relay input node and choose Create->Constant
That's the correct Relay enum type.
  • Now make copies of the correct one and replace all the others
  • Finally, remove the Enum you created into Relay and wire Relay into the Select as it was before.
  • If done correctly all the red dots should be gone.
Separately, is the status light on the Pneumatics Control Module blinking green?
Unread 07-02-2015, 18:51
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Compressor
Why does one of your double solenoids have a 0 wired to it, and the other a 1?
Unread 09-02-2015, 17:40
FRC #2001
Re: Compressor
Okay I changed the program in telop. is there anything else I need to change? Like in the Begin vi?
Unread 09-02-2015, 17:42
FRC #2001
Re: Compressor
In the begin vi the 0 and 1 corresponds with the channel in the Pneumatic Control Module that the double solenoids are using. Or at least that's what I think.
Unread 09-02-2015, 18:28
Just Itinerant
Re: Compressor
Solenoid B in Begin.vi needs the "1" changed to a "0"
To check that the PCM is setup correctly, use a web browser and type into the address bar:
roboRIO-2001.local
That should bring up web page where you'll see PCM listed on the left side.
Click on PCM and verify that the CAN ID = 0
What are the status lights on the PCM doing?
Unread 09-02-2015, 18:56
FRC #2001
Re: Compressor
roboRIO-2001.local
I changed Solenoid B to "0" and i can't find the pcm in the web browser. The status light on the PCM is blinking slow red. (No Can Com?)
Unread 09-02-2015, 19:06
Software Architect
Re: Compressor
That number corresponds to the CAN ID of the PCM itself. It defaults to zero, and should remain zero unless you're adding a second PCM to the system.
The enumerated "Solenoid 0", "Solenoid 1", etc. define which outputs of the PCM are connected to the solenoids.
If your PCM is blinking red, then you need to look at your CAN wiring and make sure it is correct. The yellow/green CAN terminals on the roboRIO should be wired to one pair of terminals on the PCM, and the other pair of PCM terminals should be wired to the CAN terminals on the Power Distribution Panel.
Unread 09-02-2015, 19:19
FRC #2001
Re: Compressor
We rewired our CAN wires (They were wired incorrectly). Now the PCM is blinking green. We have yet to test the program though.
Unread 09-02-2015, 19:38
FRC #2001
Re: Compressor
We ran into a problem where the buttons do not retract the pistons. Did i program the buttons wrong?
  #15   Spotlight this post!
Unread 09-02-2015, 19:55
Just Itinerant
Re: Compressor
If some of the LEDs next to the solenoid ports 0, 1, 2, 3 light but do not change, then there is still something wrong with the code.
Want to post the latest?
