Go to Post You've got to love the great connection between FIRST teams, and their members. - zakk [more]
Unread 07-02-2015, 15:41
The_Waffleing's Avatar
The_Waffleing The_Waffleing is offline
The Horse Shaman
AKA: Mitchel
FRC #0753 (The High Desert Droids)
Rookie Year: 2012
The_Waffleing is an unknown quantity at this point
A little confusion about the LaunhPad
So my team has decided to use the LaunchPad that came with the KOP and I know that it can be programmed using C++ and that it can't be programmed in Labiew. The only form of confusion that I have is this, how would one go about programming this micro controller? Would one go about programming all the functions that one is wanting to do with the micro-controller (i.e having a button that when pressed grabs a tote that is in the robot and lifts it up a specified distance) or can one program the functions needed in labview and port all the information over onto the micro-controller? Any info on this would be much appreciated.
Unread 07-02-2015, 16:30
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: A little confusion about the LaunhPad
The usual application is to attach it to the Driver Station for custom buttons/dials/knobs/switches, then the robot receives the values in the LabVIEW code and performs whatever actions you imagine.
Unread 07-02-2015, 16:45
The Horse Shaman
AKA: Mitchel
Rookie Year: 2012
So you're pretty much saying that both Labview and the LaunchPad need to have the code for the Auxiliary controls and just make sure that the keywords for the code correspond with each other. Or did I read that wrong.
Unread 07-02-2015, 16:53
Just Itinerant
The Launchpad needs to get setup using the FRC Gamepad Tool as described here.
After it has been setup, no coding is required.
It looks like just another joystick to the Driver Station and your LabVIEW code, and becomes just a set of Axis/Buttons.
All the code for what you do when a button is pushed or an axis twisted is entirely in your LabVIEW code.
Unread 07-02-2015, 17:00
The Horse Shaman
AKA: Mitchel
Rookie Year: 2012
Thank you that clears up a lot of questions I had in mind.
Unread 09-02-2015, 00:05
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
It just occurred to me that it would be nice to be able to program this board to expand the number of analog inputs to the RoboRIO via the USB port. That way we can get another 8 analog inputs.
Is that something that sounds feasible?
Unread 09-02-2015, 08:52
Just Itinerant
Check out this thread where they're discussing making various modifications to the Launchpad code to customize for other purposes.
