Go to Post The pie is as large as you make it. - boomergeek [more]
Unread 02-07-2015, 05:27 PM
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Rookie Year: 2010
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
SmartDashboard Extension
Hello,
I've been having some trouble with SmartDashboard extensions. I tried a simple extension that extends WPICameraExtension and has an override for processImage to return the image. I can add it to the SmartDashboard fine but it says no connection - a Simple Camera Viewer works, though. The Camera widget also says no connection. Any ideas why it isn't able to connect? I thought it was my extension at first but due to the fact that the Camera widget/extension also says no connection makes me wonder if it's something non-plugin related.
I'm using the vanilla SmartDashboard - not SFX.
Thanks.
