Go to Post When mentors and students battle it's the team that loses. - Koko Ed [more]
Unread 07-02-2015, 17:39
jon_bui jon_bui is offline
FRC #3882
jon_bui is an unknown quantity at this point
TI Launch Pad Button Not Working
I'm trying to test out the KOP TI Launchpad. I've successfully flashed it with the Gamepad Tool for FRC, using option 3. My driver station recognizes the launchpad as a joystick, but the Driver Station doesn't recognize button pushes. I just have one button for now, one wire is plugged into gnd and the other has been plugged into p4.1. I've use the diagram on the gamepad tool to try all the other pins designated for buttons. But no luck. Any advice?
Unread 07-02-2015, 17:56
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: TI Launch Pad Button Not Working
The LaunchPad has pull down resistors, so you need to connect from the port to 3.3V.
There is an image here:
http://processors.wiki.ti.com/index....igital_Buttons
(This is a change from the Stellaris LaunchPad from 2014)
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 07-02-2015, 18:33
FRC #3882
Thanks, it worked. You're the man!
Unread 08-02-2015, 00:18
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Mitch got ours working today. Course he spent over 2 hours to correctly map the inputs to the correct wires. Now to build us a box to house the thing.
Unread 08-02-2015, 16:29
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
We ran into a minor issue yesterday with the LaunchPad.
If we boot the DS with the LaunchPad connected, Windows recognizes it and it is displayed on the DS along with the Joysticks. Although, button presses are not sensed or displayed.
Now if we connect the Launchpad after Windows has booted, everything works correctly. This would be a major issue if the LaunchPad was buried inside our Drives's Station, or access to the USB connectors on the laptop were not easy to access. Fortunately, the portion of our Driver's Station where the LaunchPad is is a separate box and won't be plugged in until the laptop is booted.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 08-02-2015, 16:46
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Does F1 still refresh joysticks, and does that help?
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 08-02-2015, 17:05
wt200999's Avatar
Texas Instruments
AKA: Will Toth
I was able to replicate this in a VM. In addition to your description, I also tried 'soft' disconnecting the device from the Windows VM (board itself stays powered) and reconnecting it, and I still was unable to get button inputs. So in this case the device requires a full reset.
On that note, and while not optimal, you can use the RST button or pin to force a reset. That seemed to work on my end to get the button inputs responding again.
Also rescanning or using F1 did not work to get the buttons responsive again.
I've submitted a bug for this on Github and we will take a look at it.
Unread 08-02-2015, 17:18
billbo911's Avatar
Thanks for submitting the Bug!
Accessing the RST button on our Co-Pilot console is not an option. The LaunchPad is buried inside a closed 14" X 14" button box.
So, until a fix comes out, we will just not plug the box in until the Laptop is fully into Windows.
Unread 08-02-2015, 23:27
AKA: Mr Tanguay
Guess we'll plan to make the reset button accessible from outside the box. Thanks for the "heads-up".
Unread 09-02-2015, 11:52
billbo911's Avatar
Just make sure the button isn't too easily accessed. The last thing you want to do is accidentally hit it right in the middle of a match!
