Go to Post I think Dave has been spending time on icanhascheezburger. Either that or the fumes from his rendering machines have affected the grammar control portion of his brain. - rsisk [more]
Unread 08-02-2015, 09:51
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: Using wood on a robot
Originally Posted by scaryone View Post
Use Baltic Birch plywood. Advantages often outweigh aluminum. Wood will bend without breaking and bounce back into shape (of course to a limit). We often feel that wood weight vs strength makes birch superior. Also, so darn easy to work with. Over 80 matches last year (and some really rough ones) and the bot looks like it did on bag and tag day.
Riot crew always builds such sweet (wooden) machines.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 08-02-2015, 01:44
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
Originally Posted by lopsided98 View Post
Yes, wood is a perfectly good material. There are some teams that make almost all of their robot out of wood.
The wood PWM wires are really slick! The color coding was from the three different types of tropical hardwood used.
Unread 08-02-2015, 02:08
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
We used a wood claw in 2007. That robot won 2 regionals, made it to Einstein, won a regional quality award and a regional and championship Industrial Design award. The claw was also featured in the 2007 behind the design book. http://www.amazon.com/FIRST-Robots-R...ind+the+design
Unread 08-02-2015, 06:16
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
http://blog.kidrobot.com/product-pre...wooden-bender/
...the way nature intended
Laminated wood is plenty strong and if there is any doubt; many of you are probably reading this while sitting on a floor supporting your weight on plywood.
One could argue, depending on the scope of the analysis, wood is actually more ecologically friendly. When you consider the way you get your aluminum, steel and plastic and trace it all the way back to the trees, mines and oil wells. Course wood gets a lot less ecofriendly if you use commerical fertilizers.
Unread 08-02-2015, 14:44
2508electronics 2508electronics is offline
The One Man Electrical Team
FRC #2508 (Armada Robotics)
Team Role: Electrical
Rookie Year: 2013
2508electronics is an unknown quantity at this point
We use wood as a base and a panel for the electronics all the time. Also, we do what we call "aluminizing" the wood to all of the piece which basically means spray paint it an aluminum color. That gets interesting during inspections occasionally. Last year the inspector went to test continuity to make sure the frame wasn't being used as a ground and put one of the multimeter probes on the "aluminized" wood base and was surprised when we told him it was wood.
Unread 08-02-2015, 14:46
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Wood this year:
spacer inside 1" square aluminum tubing
spacer inside manipulator mechanism
component of manipulator
Previously:
electrical panel
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 08-02-2015, 15:02
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Originally Posted by MrRoboSteve View Post
Wood this year:
Previously:
electrical panel
Wood this year:
Robot
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
