Thread Tools |
Rating:
Display Modes |
Can someone verify that I wired/am using this potentiometer correctly?
http://www.mouser.com/ProductDetail/...Rnf9DwYA%3D%3D This is the specific pot.
Terminals 1 and 3 are connected by a wavy line. Ground is going to terminal 1, power is terminal 3, and signal is terminal 2. Moving the pot with a voltmeter on signal and ground shows a change in resistance. The PWM is connected to channel 2 in the analog input. I've had the code verified to be working correctly, but the code will only output one value for the pot. Any sugestions? |
