Go to Post And trust me, the very last thing you want to see is me with time on my hands and access to power tools. - dlavery [more]
Unread 02-07-2015, 10:30 PM
PredaFran PredaFran is offline
Amateur Programmer
AKA: Francisco
FRC #5285 (Sea Kings Robotics)
Rookie Year: 2015
PredaFran is an unknown quantity at this point
Post Help with toggle-button
We would like to be able to press a button in the joystick, and that for example if the joystick was controlling motor 1, it would control motor 2.
Thanks in advance.
Unread 02-08-2015, 12:00 AM
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Help with toggle-button
My team does type of action for our dual acting solenoid.
Code:
bool isReady;
bool Piston;
isReady = true;
Piston = false;
if (DriverJoyStick.GetTrigger() && isReady && !Piston){
		Piston = true;
		isReady = false;
} else if (DriverJoyStick.GetTrigger() && isReady && Piston {
		Piston = false;
		isReady = false;
} else if (!DriverJoyStick.GetTrigger()){
		isReady = true;
Where when you press the DriverJoystick Trigger and release it, it toggles the Boolean HalfSpeed. The Boolean you can set later in your code. We use it such as.
Code:
if(Piston){
	piston.Set(Relay::kForward);
} else if (!Piston){
	piston.Set(Relay::kReverse);
Unread 02-08-2015, 12:50 AM
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
Could you give me more info about it? or a simpler version using two motors only?
Thanks in advance
Unread 02-08-2015, 01:26 AM
All you would have to change is this part of the code assuming you keep Booleons named the same:
Code:
if(Piston){
To something like this:
Code:
if(Piston){
	Talon1.Set(Stick.GetY()); // Where as the talon1 would be controlled by the Y axis of the Joystick
	Talon2.Set(Stick.GetY());// Where as another talon, talon2, would be controlled by the Y axis of the Joystick
Unread 02-08-2015, 04:53 PM
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
i have this code so far, i cant get it to work, any idea of what could be wrong?
Code:
#include "WPILib.h"
class Robot: public SampleRobot
	bool Piston;
	Joystick stick; // joystick
	Piston = false;
	Talon m_motor1;
	Talon m_motor2;
public:
	Robot() :
		m_motor1(1),
		stick(0)
		myRobot.SetExpiration(0.1);
	if(Piston){
		m_motor1.Set(Stick.GetY()); // Where as the talon1 would be controlled by the Y axis of the Joystick
		m_motor2.Set(Stick.GetY());// Where as another talon, talon2, would be controlled by the Y axis of the Joystick
START_ROBOT_CLASS(Robot);
Unread 02-08-2015, 06:17 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You left out the part where you read the joystick button and set the flag you're calling Piston. It's always going to be false.
Unread 02-08-2015, 06:22 PM
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
could you give me a hand with it? im still new in the field of c++ robotics.
Thanks in advance
Unread 02-08-2015, 06:45 PM
Software Architect
tomy's first reply to you gave the toggle code you are looking for.
Unread 02-08-2015, 07:00 PM
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
thanks for the reply, but i dont quite get what im supposed to do
Thanks in advance
Unread 02-08-2015, 07:51 PM
Software Architect
I'm not skilled enough with C++ to help you in this kind of back-and-forth forum posting. It seems likely that your level of understanding is such that you would be best served by someone helping you in person. Do you know any other teams in the Long Beach area?
Unread 02-09-2015, 01:54 AM
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
Unfortunately, I don't thanks for the help tho
Any thing you think i should read to get more informed in the subject or another place to get help from are appreciated
Unread 02-09-2015, 10:02 PM
FleventyFive FleventyFive is offline
FRC #4118
FleventyFive is on a distinguished road
Here is some commented code that does what you want to get you started. If you are the only programmer on the team though, I agree you should try to find a mentor or another student who can help you out if you don't have much experience. Also, don't be afraid to read the errors and warnings eclipse is giving, often they make sense. Good luck!
Code:
#include "WPILib.h"
{ //Define any variables like motors, sensors, or values here
	bool UseSecondMotor;
	Joystick stick;
	Talon m_motor1;
	Talon m_motor2;
public:
	Robot() : //Here is where you say what motors/sensors go into what ports on the RoboRio or the DriveStation computer, for example m_motor1 is in PWM port 1
		stick(0), //Change the 0 to the correct joystick, they are numbered from the order you plug them in
		m_motor1(1), //Change this to the correct PWM port where motor 1 is plugged in (ask electrical team)
	 	m_motor2(2) //Change this to the correct PWM port where motor 2 is plugged in (ask electrical team)
		//You can set the initial value of variables and do things like enable motor safety here
		UseSecondMotor = false;
	void Autonomous() //Where you will put the code that runs durring the Autonomous period of the match
	void OperatorControl()
		//Put anything you want to happen once at the start of teleop here
		while (IsOperatorControl() && IsEnabled()) //This runs every 5 milliseconds in teleop, use it to read joystick values and write speeds to motors
			UseSecondMotor = stick.GetRawButton(1); //Change the 1 to whatever button on the joystick you want to use to toggle (they are labled)
			if (UseSecondMotor) m_motor2.Set(stick.GetY());
			else m_motor1.Set(stick.GetY());
			Wait(0.005); //Don't remove this, this adds a delay so the computer doesn't crash and the motors have time to update
	void Test() //This is what runs when you click on test mode in the driver station, use to test motors, sensors, etc
