Go to Post (You know you're overdosed on FIRST) when watching regional web-casts takes precedent over Saturday morning cartoons. - Hawiian Cadder [more]
Unread 08-02-2015, 00:19
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
1444's First Fully TIG-Welded Frame
Hey all,
Team 1444 acquired a Diversion 165 for our shop this year and immediately assigned it to main welding duty. We've had a larger Miller MIG that has been holding it down for years, but we decided to step up our game and fully TIG the robot this year. We've had sub-assemblies TIG welded before, but never the entire robot. So far, we are very pleased with how things are turning out. The 165 isn't quite up to some of the thicker plate used in the gearboxes, but that's nothing multiple passes can't solve. Students and mentors alike are still learning, but it has been a lot of fun so far and we are looking forward to more TIG'd goodness in the future.
Frame sub-assembly:
Frame tacked and ready for seam welding:
Fully welded (for now):
Several dimes have been stacked...
Unread 08-02-2015, 00:45
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud of
Re: 1444's First Fully TIG-Welded Frame
Very nice and clean looking weld lines. Just wondering if you will have any weight issues when the robot is fuly assembled?
Team member 2004-2008
Team mentor 2008-2014
http://team1708.steelcityrobotics.or...tics/Home.html
"12 years as a student and mentor and proud of it"
Unread 08-02-2015, 01:29
DarkRune DarkRune is offline
AKA: Dylan Baker-Flynn
FRC #4159 (CardinalBotics)
Team Role: Driver
Rookie Year: 2012
DarkRune is a jewel in the roughDarkRune is a jewel in the roughDarkRune is a jewel in the rough
Don't know why, but I'm getting a 2014 robot vibe from this haha. Anyway, can't wait to see it when its complete, I bet it will be gorgeous.
Good luck!
Unread 08-02-2015, 12:08
Eh...it's hard to say. That frame only weighs 14lbs. But we are a little worried about weight, so we are taking some lightening measures now.
Good luck!
Haha. Well so far it looks quite a bit different than our 2014 robot. Black paint might happen again, though. ;-)
Unread 09-02-2015, 02:29
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Do you have details on the alloys of the extrusions, plates and filler metal, and the heat treatment (if any)? I'm curious if there was explicit consideration of the reduction in temper of the alloy due to welding (heat-affected zone).
Also, let us know if there's any trouble fitting bearings into the machined holes, due to distortion in the welding process. Did you use jigs to ensure the gearboxes remain square? Or are you planning post-weld/post-heat-treatment finish machining?
Unread 09-02-2015, 09:29
Everything is 6061 T6 with 4043 filler done with 100% Argon. With the thicker plates, we did do some preheating to aid in getting decent penetration and we make some attempt to slowly cool the pieces. Early on, we had some students quenching parts which is a big no-no.
On this particular assembly, we did use a jig to keep the bearing holes centered. On some of our smaller assemblies (i.e. those that will fit on our mill), we will machine them after welding.
Thanks for the comments!
Unread 09-02-2015, 12:10
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
FRC Video Review - Change is Coming
FRC #4329 (Lutheran Roboteers)
Team Role: Coach
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Looking great guys, 1444 always makes some of the coolest stuff all in-house.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 09-02-2015, 12:16
Shrub's Avatar
Shrub Shrub is offline
no team (N/A)
Rookie Year: 2014
Shrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant future
It's so beautiful the frame looks like it's going to be very interesting!
Unread 09-02-2015, 16:00
Thanks guys!
Unread 09-02-2015, 16:03
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Lookin' pretty good!
Who is doing the welding and what sort of parameters/consumables are they using?
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 09-02-2015, 17:35
It has been a mixture of students and mentors. Despite being an EE, I've become our main welding mentor; I think I'm the only one crazy enough to do it.
We've been using Hobart MaxalTIG 3/32" and 1/16" 4043 filler, green (pure) tungsten electrodes, and 100% Argon. (All generously donated by a sponsor, Delta Gas and Welding Supplies!) We just got some ChemSharp for sharpening electrodes and I swear that stuff is magic...SO much better than grinding. We use the Miller footpedal and a Weldcraft A-150 flex valve torch.
Our Diversion 165 is pretty light for some of the stuff that we do, so it has been maxed out most of the season. A few of our weldments required multiple passes with preheating. It does great for 1/8 and 1/16 wall tubing, though. We've gotten some X-Ray-quality welds on that material.
Unread 09-02-2015, 19:38
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Very nice!
I would suggest two things (as someone who has earned certs in aluminum and steel TIG):
1) 50/50 Ar/He gas is wonderful, especially for welding thicker aluminum sections. The added heat transfer from helium allows you to weld thicker material at lower currents as well as run higher currents on smaller electrodes. Welding thin sections also benefits from 50/50 as well.
2) Toss the pure tungsten, it is pure garbage. I know it's 'old school' to use pure tungsten, but it's simply not as good as alloyed tungsten in current capacity or arc stability. A zirconated (yellow) or E3 (purple) tungsten will hold a point under load, resulting in better arc control, and the end will never melt and fall into the weld pool.
Otherwise, keep up the good work!
