Go to Post I blame FIRST for everything good that has happened to me. - Herodotus [more]
Unread 08-02-2015, 16:30
runger723 runger723 is offline
FRC #3506
runger723 is an unknown quantity at this point
Max number of motors per talon?
Just pointing out a discrepancy in the rules that I noticed. We were hoping to control two motors from the same talon, but in section r42 of the rules it seems to imply that that is not allowed. However on the robot inspection sheet given to the judges, it seems to say otherwise. Can a talon control more than one CIM motor at a time?
Unread 08-02-2015, 16:33
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Max number of motors per talon?
No. They cannot.
Rule 42 says this.
R42 Each power regulating device may control electrical loads per Table 4-4. Unless otherwise noted, each power regulating device
may control one and only one electrical load.
The manual trumps other documents.
The sheet is worded poorly. Because it says the same thing but is not straightforward.
Motor/Actuator Power – CIMs, AM 9015s, Banebots, & VEX motors must be fed by only one (1) motor controller. Each motor controller may have up to two (2) of other motors connected to load terminals (Table 4-4). Single specified motors may be connected to Spike (however multiple pneumatic valves may be driven by a single Spike). <R42, Table 4-4>
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 08-02-2015, 16:35
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Go by the rules, always. Don't try to control two CIMs with one Talon (or Victor).
Also, the judges do not get inspection sheets. Thanks, your Robot Inspectors.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 08-02-2015, 19:06
Bob Steele's Avatar
Bob Steele Bob Steele is offline
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
In table 4-4 It states that you can use a single motor controller for up to 2 of the following motors only:
Automotive Window/Door/Windshield
Wiper/Seat Motors
AndyMark PG
Bosch Motor
Snow-Blower Motor
Denso Throttle Control
When the check list references "other" motors the ones listed above are the ones being referred to.
The following motors must each have their own motor controller
CIM
AndyMark 9015
Banebots
VEX BAG/MiniCIM
These are not "other" motors... they are motors...
(I must admit that this could be confusing... if one does not READ the rules)
This is all in table 4-4 and the table is referenced in the inspection check list.
The check list is just that... an abbreviated check list that references the rules of the game.... it is not a stand alone document.
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
