Go to Post If your logo is your team number in a font 4" tall in 1/2" stroke, colored/outlined in white, then yes. Otherwise, no. - cadandcookies [more]
Unread 08-02-2015, 19:26
petercooperjr's Avatar
petercooperjr petercooperjr is offline
AKA: Peter Cooper Jr.
Rookie Year: 1999
petercooperjr is an unknown quantity at this point
Playoff Average Tiebreaker "Extra Point" math
While studying to be a referee for this year's game, I've come up with an odd question. I can't ask it on Q&A since I'm not really on a team anymore, but I'll post it here and I'm hoping somebody would be so kind as to ask it on Q&A for me (or point out to me something blindingly obvious that I'm missing, which is also entirely possible). Thanks.
Section 5.4.3 “Playoff Advancement” says “In the case where the average score of two (2) or more ALLIANCES is equal, the tie is broken by awarding an additional point to the ALLIANCE’s average score using the tiebreaker rules shown in Table 5-2.” Does that mean that if alliance 1 has a Playoff Average of 100.00, and alliances 2 and 3 each have a Playoff Average of 99.50 but alliance 3 scored more Auto points than alliance 2, that alliance 3 would end up as seed #1 for the next round due to having an effective average of 100.50 due to the extra point added to break the tie?
I'm assuming that's not what was intended, but the “awarding an additional point” seems like it may end up doing something like that. It gets even weirder if there are three or more alliances tied at the same Playoff Average.
Unread 14-02-2015, 09:14
the duderoni the duderoni is offline
AKA: Connor
FRC #1559 (Devil-Tech)
Team Role: Scout
Rookie Year: 2014
the duderoni will become famous soon enough
Re: Playoff Average Tiebreaker "Extra Point" math
I'm pretty sure that in your case Alliance 1 would be first seed since they do not need a tie to be broken, then Alliance 3 because they won the tie breaker against Alliance 2, and then finally Alliance 2 would be third seed.
Tie breakers do not add points to your qualification average, they are just considered second when determining playoff seed.
Unread 14-02-2015, 12:22
Kevin Leonard Kevin Leonard is offline
Professional Stat Padder
FRC #5254 (HYPE), FRC #20 (The Rocketeers)
Rookie Year: 2011
Kevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond repute
The way the rules are written, that would appear to be the way the rules read- that that extra added point could shake up alliance rankings by multiple spots. However I'm not sure that was the intent of the rule.
This would be a good Q&A. Nice catch!
All of my posts are my opinion only and do not reflect the views of my associated teams.
College Student Mentor on Team 5254, HYPE - Helping Youth Pursue Excellence
(2015-Present)
Alumni of Team 20, The Rocketeers (2011-2014)
I'm attempting a robotics blog. Check it out at RocketHypeRobotics.wordpress.com Updated 10/26/16
Unread 14-02-2015, 13:20
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
Rookie Year: 2007
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
I would think it would be an "extra point" to just break the tie, but the alliance would retain its same position in reference to the other alliances.
But, like other have said, good catch for a Q&A question.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 14-02-2015, 13:43
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Since the FMS system determines the order, it will probably work the way you think it should (cannot increase your alliance position).
Another question is: If, after all the tie breakers, two or more alliances are still tied, then another match is played.
This is required if it would eliminate a team from the Finals.
But, what if the top 2 alliances are tied (and or more teams are advancing)? Since the only thing affected is pairing due to placement, would a match be played, or Random?
