Go to Post If you're the smartest person in the room, you're in the wrong room - Ian Curtis [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 09-02-2015, 09:01
orwn orwn is offline
FRC #4320
orwn is an unknown quantity at this point
Setting Up Axis Camera
Hey,
Our team has been using axis cameras (M1013 and M1011) for the last few years.
Normally, we don't encounter any problem while setting up the cameras.
However, for some reason this year our cameras refuse to work.
We plugged the camera into 5 V and 2 A from the VRM, then we connected our camera to the laptop through crossover ethernet cable, we changed the local IP of our laptop into 192.168.0.6 and the subnet mask into 255.255.255.0, and we disabled the wifi.
When we tried to browse to 192.168.0.90 (the default IP of the camera) the page wasn't exist.
The net led , the power led and the face led were light green while we tried to set them up.
We tried this with several cameras, non of them worked.
We reset all of war cameras.
We disabled our fire wall.
It didn't worked..
What did we do wrong?
Thanks,
The Joker #4320
Unread 09-02-2015, 10:53
gadet gadet is offline
AKA: Danny Qiu
FRC #0694 (StuyPulse)
Rookie Year: 2011
gadet is an unknown quantity at this point
Re: Setting Up Axis Camera
This can be due to your camera retaining it's IP from previous years. Did you change the static IP of the camera at any time?
Our team encountered this problem a while back and to find the IP that we changed the camera to, we had to use Wireshark and sniff out the packets from the camera.
Unread 09-02-2015, 11:39
FRC #4320
Interesting.. we didn't change the static IP of the camera.
Shouldn't the IP reset to 198.168.0.90 when I push the reset button?
I'll try to use the wire shark for sniffing it.
Thanks!
Unread 09-02-2015, 11:59
FRC #4320
Another thing I forgot to mention that we tried to use to Axis Setup tool and it didn't work too..
So should it find the camera even if it stay with it's older IP?
Unread 09-02-2015, 12:25
billbo911's Avatar
billbo911 billbo911 is online now
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Thanks!
The process to reset the Axis cameras is a bit more than just pressing the reset button. (What, do you want everything to be easy? )
Here is the process from the M1013 user's manual.
1. Disconnect power from the product.
2. Press and hold the Control button and reconnect power (see Hardware Overview, on page 4 ).
3. Keep the Control button pressed for about 15 seconds until the Status indicator flashes amber.
4. Release the Control button. The process is complete after about 1 minute (when the Status indicator turns green). The
product has been reset to the factory default settings. The default IP address is 192.168.0.90
5. Re-assign the IP address.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 09-02-2015, 14:54
FRC #4320
THANK YOU VERY MUCH!!!!!!
It finally worked!!!!
