Go to Post One last thing, if a mechanical part fails on you, sometimes you can get a little bit of noise back into it by yelling at it, kicking it, or pounding on it with your fist. This might put enough back into it so it will work for a few more minutes. - KenWittlief [more]
Unread 09-02-2015, 16:19
mistersands mistersands is offline
FRC #4528 (Automatons)
Team Role: Coach
Rookie Year: 2013
mistersands has a spectacular aura aboutmistersands has a spectacular aura aboutmistersands has a spectacular aura about
RoboRio not taking new code
So we deployed the new build, but the RoboRio is still acting as if the old code is on it.
We use Java with Eclipse. It says build successful when we deploy the code, but it isn't taking the new code.
We've removed all code calling a certain button, but that button still works.
Anyone have this problem and know how to fix it?
Unread 09-02-2015, 16:27
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: RoboRio not taking new code
If the directory configuration gets out of whack somehow, you might be deploying an old copy of the program that isn't being updated when you build the code. Have you recently copied things from one directory to another? Make sure all the project information is pointing to the new location.
