Go to Post When the world gives you lemons make lemonade serve it at your press conference to expand the program. - Koko Ed [more]
Unread 09-02-2015, 19:07
dougwilliams's Avatar
dougwilliams dougwilliams is offline
Engineer - Controls, Electronics
FRC #2053 (TigerTronics)
Rookie Year: 2013
dougwilliams is on a distinguished road
Has anyone run OpenCV in a separate WPILLib Task / Thread on the RoboRIO?
Just wondering if anyone has had any luck getting OpenCV (or for that matter, any) functions to run in a separate WPILib task / thread on the RoboRIO?
If you had it would be helpful to know how well it works in terms of eliminating latency in your main robot code? We also need help in implementing the task creation. If someone has example code they could point me to for making a new thread (not necessarily OpenCV) that would be great to use as a reference for proper implementation of the WPILib Task functions.
Unread 10-02-2015, 00:22
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
Rookie Year: 2012
calcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nice
Re: Has anyone run OpenCV in a separate WPILLib Task / Thread on the RoboRIO?
If you're using C++, you can make a new thread with std::thread. http://www.cplusplus.com/reference/thread/thread/
Use std::mutex for synchronization (i.e. variable passing) between threads. std::future would also work well here.
Unread 12-02-2015, 02:20
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
Rookie Year: 2007
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
My team has been using tasks for a variety of things for years now. All our tasks are simply based on a class jankyTask. Please see the following post for links to the github code and a write-up I did on how it all works a few years ago.
http://www.chiefdelphi.com/forums/sh...ght=Tasks+in+C
RoboBob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 12-02-2015, 07:56
jreneew2's Avatar
jreneew2 jreneew2 is online now
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
Rookie Year: 2013
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Yep. We just got that implemented last night and our code is on our git hub page.
https://github.com/team2053tigertron...DRobot2015/src
It is in the robot.cpp file
Unread 12-02-2015, 10:18
jreneew2's Avatar
AKA: Drew Williams
Rookie Year: 2013
I just realized you posted this! Oops! Well I guess we solved our own problem! Well, it works now.
Unread 12-02-2015, 16:57
FleventyFive FleventyFive is offline
FRC #4118
FleventyFive is on a distinguished road
Are you okay with other teams using part of this project? Also, what version of OpenCV are you linking to and how did you get/compile it? Thanks
Unread 12-02-2015, 17:41
jreneew2's Avatar
AKA: Drew Williams
Rookie Year: 2013
Post Re: Has anyone run OpenCV in a separate WPILLib Task / Thread on the RoboRIO?
Yeah, you are ok to use it! We are still refining the vision code for detecting totes though so you should redo that part if you can do it better. For compiling and linking, this is a lengthy process. We used just plain OpenCV2. We followed team 2168's linking instructions which are a bit vague so I will try and explain.
1. Download our OpenCV project from our github here. And move the project somewhere safe (we have C:\OpenCV_frc\arm\include\OpenCV\opencv2)
2. Then I assume you have an existing project for C++ (im not sure if this differs from java) go open eclipse and right click on your project go to Properties->C/C++ Build->Settings. Then go to the tool settings tab and click on Cross G++ Linker and add -rpath,C:\OpenCV_frc\arm\libs\opencv (what ever your directory is). Also make sure you have a comma in between entries.
3. Then go to C/C++ general and go to paths and symbols. Click on the library paths tab and hit add. Add the directory from your file system and type in C:\OpenCV_frc\arm\libs\opencv (what ever your directory was) hit apply.
4. Then go to the Libraries tab and add opencv_core,opencv_highgui,opencv_imgproc from C:\OpenCV_frc\arm\libs\opencv (whatever your directory is)
5.Now hit apply and add the cpp and h files in a folder in your project. we have our called Vision2015. Then add the necessary includes and and using namespace cv;
6. You should be able to compile and run the robot. You might want to see how to run the code on a separate task though because it will slow down drive code if running in a separate task. Our actual robot project in robot.cpp shows how to do that.
Please feel free to reply if you have any questions. Also, if you improve the tote detector in any way, contact us.
Have a fun time!,
Drew (2053 Programmer)
Unread 13-02-2015, 14:25
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
Rookie Year: 2012
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
Have a fun time!,
Did you get the tracking working on the RoboRio? Last I saw everything was a tote. I am assuming you got it working because Jason had it working on the laptop and this should of been a straight up port. I ask because when I saw it earlier yesterday it was running in the separate thread OK it just wasn't tracking right yet.
Unread 13-02-2015, 16:28
jreneew2's Avatar
AKA: Drew Williams
Rookie Year: 2013
Yeah, it was working when you were video conferencing with us. We just have to refine the colors.
Unread 13-02-2015, 16:33
Rookie Year: 2012
If you update wpilib c++ robot development, be sure to go into wpilib.h and comment out #define REAL
Unread 13-02-2015, 22:23
FRC #4118
Have a fun time!,
Thanks for the great instructions! However, every time I setup a project (including importing yours and fixing the paths to opencv) I get like 175 errors in opencv2/core/core.hpp. I had the same problem when I tried earlier in the season to get opencv in the project. Any idea why I would get so many errors? Sound like something to do with the index, but I've rebuilt in many times.
Edit: followed PaulDavis1968's suggestion to comment out that line in WPILIB. No idea what that does, but it fixed it!
Unread 15-02-2015, 14:30
jreneew2's Avatar
AKA: Drew Williams
Rookie Year: 2013
Yeah, we found that out the hard way. After searching forever through OpenCV and wpilib we found that REAL is defined in both wpilib and OpenCV. Good luck with auto!
